If you hold the numbers depressed too long, the program puts the same number in the next array space. So, I am going to have to revisit the decode section. It is interesting that the dtmf chip is disabled at the time of data entry of the decoded number into the array. Also, only one verbal response plays.
Travin
No need to post a reply to myself. I debounced the software with a Pause 500 just before "until c > 7", and it worked like a champ. I tried several different pauses during tone entry and never had another repeat. So, thinking I had it solved, I placed the corrected code into the original code and whalla, the same problem. So, I guess the if then statements on the password section are bunk. It still won't play the error message if the entry is wrong, it won't go to the menu message if the entry is right, and it still starts over after pressing a random number of buttons on the phone after all eight digits of the password have been input.
assword[c]=dtmf
