Thanks for pointing out the portc = %000100100. That controls the address of the isd chip. One zero on each side shouldn't be there. Unfortunately, that didn't fix it. Its not the dtmf that doesn't work. It is getting the data into a usable form. Once the phone picks up, the user pushes a button on the key pad. The pic then makes the isd chip play the welcome statement, which asks the user to enter their password, which in this case is 12345678. During the entry of the password, I tried to make each entry go into an array via the select case command. During this progression, I advanced the var "c". When "c" reached 8, I compare each individual array segment to the individual section of that password. This is where the code stops working. It doesn't give me the error message and doesn't go on to the next step of the program. I am not sure if I am getting the code inputed correctly nor am I sure that I am comparing it correctly. Thanks for the catch though.
Travin
