A little DTMF help
Results 1 to 40 of 49
Threaded View
  1. #17
    Default Ok
    I guess I am just confused here. The led subroutines are merely a visual aid for the debuggin process. I have about 10 different program written for this contraption. I started with each section of the main program until it worked correctly. Then I moved to the next section and so forth. When I put them all together, they don't work. Like for instance, in the previous post, the branch command didn't work. The led didn't blink on and off for 3 seconds. I know this routine is good. Also, I shouldn't have to push a button twice to go from the if then statements of the password comparison to the menu_message, but it will just sit there until I press two buttons. I know that is no where in the code so I am confused as to why it is like that. Thanks for the help, and I am not uposed to learning. I do a couple of questions for you, in your code you wrote, you have this:
    Lookup dtmf-"0",[%10101001,....... My question is what is -"0" for?
    Also,
    dtmf = 0:dtmf.0=DT0:dtmf.1=DT1:dtmf.2=DT2:dtmf.3=DT3
    LookUp dtmf,["_1234567890*#"],dtmf how does the lookup table know which number has been decoded by using this sequence: dtmf.0=DT0:dtmf.1=DT1:dtmf.2=DT2:dtmf.3=DT3
    Travin
  1. DTMF on a 12V car system
    By Jumper in forum Schematics
    Last Post: - 7th December 2008, 14:41
  2. DTMF output
    By din_kt in forum mel PIC BASIC Pro
    Last Post: - 28th February 2008, 14:24
  3. DTMF Decoding?
    By muddy0409 in forum General
    Last Post: - 19th December 2007, 15:28
  4. Replies: 2
    Last Post: - 31st July 2006, 16:06
  5. Problems with DTMF Generatiom
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 21:12
