Input?
Results 1 to 3 of 3
Thread: Input?
    You're 99% of the way there... here's an amendment that should get you all the way...
    Led Var PORTC.1
    Sensor var PORTC.2
    TRISC=%00000100
    high Led
    pause 5000
    low led
    loop:
    if sensor = 1 then
    high led
    low led
    goto loop
    On the PIC16F688 RC1 & RC2 (and others - see datasheet) are A/D inputs by
    default on power-up. Add this to the first section of your code;
    ANSEL = 0
    That will allow use of these pins as digital.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 23:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
