sound command & music
Results 1 to 15 of 15
    And now, if you want to do a 'little' improvement, you may use a PIC with a HPWM module and, if possible, use this module to generate the tone. This may avoid some unwanted 'distortion' in the tones. HPWM will continue to play the tone, while sending your info to the LCD. BUT as i'd didn't heard the actual result, i can't say if it's going to be a real improvement.
    trying's Avatar
    trying Guest
    As I study the "Yankee" code more I understand CounterA is READing the DATA but I am still not sure how take the note from a frequency to DATA
    grand kids say more music papa
    can some one explain this were a newbie can understand it
    thanks.
    ' Musical Note/Frequency/Period/Cycles for 250mS
    ' Cs means C Sharp
    ' Df means D Flat
    ' There are four Data statements per Note...
    ' Byte 1 is the MSB of half the Period Frequency
    ' Byte 2 is the LSB of above
    ' Byte 3 is the number of cycles the note will play for
    ' (divided by ten). All the notes have been calculated
    ' to Beep for approx 250mS except the last two notes
    ' of each line which are twice as long.
    ' Byte 4 is the time delay in mS (divided by ten)
    ' that follows any given played note.
    Data $01,$3F,$27,$10 ' G7 - 1567.98Hz 638uS 390c
    Data $01,$1C,$2C,$10 ' A7 - 1760.00Hz 568uS 440c
    Hi Trying. Hi Steve. Using the PWM module is a BIG improvement as each note will be perfectly on key. I converted some tunes into HPWM commands to play music on one of the PWM ports on a 16F818. The 818 can hold about 2 or 3 songs, the 16F819 can hold about 5 and a 16F88 that I used holds 8 different tunes. Below are 2 of them. If you want more volume, output the CCP1 pin to the gate of a FET. Source to ground and speaker from drain to B+. It will be painfully loud. I used a logic-level IRLZ44N at 3 Volts for this. Add the command CCP1CON = 0 and make the port LOW at the end of the song otherwise the FET may be left ON and kill the battery. CAUTION - writing songs and playing them on a PIC can be addicting! Be prepared to spend countless hours writing code.
    BABABLACKSHEEP:
    HPwm 1,127,262:Pause 320
    HPwm 1,127,392:Pause 320
    HPwm 1,127,440:Pause 160
    HPwm 1,127,494:Pause 160
    HPwm 1,127,523:Pause 160
    HPwm 1,127,000:Pause 320
    HPwm 1,127,349:Pause 320
    HPwm 1,127,330:Pause 320
    HPwm 1,127,294:Pause 320
    Pause 1000
    GoTo BABABLACKSHEEP
    STARSPANGLEDBANNER:
    HPwm 1,127,698:Pause 320
    HPwm 1,127,587:Pause 320
    HPwm 1,127,466:Pause 640
    HPwm 1,127,587:Pause 640
    HPwm 1,127,698:Pause 640
    HPwm 1,127,932:Pause 640
    HPwm 1,127,000:Pause 640
    HPwm 1,127,1175:Pause 320
    HPwm 1,127,1047:Pause 320
    HPwm 1,127,659:Pause 640
    HPwm 1,127,1175:Pause 640
    HPwm 1,127,880:Pause 640
    HPwm 1,127,784:Pause 320
    HPwm 1,127,880:Pause 320
    Pause 1000
    GOTO STARSPANGLEDBANNER
    Funny things amuse grand kids here!
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=881&stc=1&d=1148640458 ">
    Now if there's any existing software to convert music sheet or MIDI sequence to note/duration table it could be just much easy... i'm sure it exist.
    Wink Music ... yessss
    Hi, Steve,
    In my old papers (Electronique pratique 277 )... i've found something interesting !!!
    See a 16F84 reading a 24C256 gives 4 sec of sound.
    ...output on portB with a R -2R ladder ... amp is a LM386.
    Buuuuuut, where it becomes interesting ... is you can load the EEPROM using the Windows sound recorder ... aha !!!
    now, the Wave file has 58 bytes at top to config ...to wipe off !!!
    in the Wav-bin.exe, that's done automatically.
    then just have to load the EEPROM...
    Listen, that's all !!!
    Problem ... the 200Kb limit is widely exploded !!! ... have an address to post that ???
    Dropped in your PM !
    Interesting but there's some additionnal hardware. Even some ISDXXX chipcoder would do the job as well. Let's see what we can with your suggestion. Will report something here... one day... when i'll found time to play 'round.
    trying's Avatar
    trying Guest
    Quote Originally Posted by mister_e
    thats great guys but thats wayyyyyy over my head (right now)
    ok mister_e I just finished a spead sheet with excel that has 4 octaves of notes gives you the note freq,period time,note repete time and other things
    for 1/16,1/4,1/2 and whole notes. but I'm stuck on how to use this with
    MSB, LSB, in data the way Melanie used it in "Yankee doodle" for give me for not knowing how to ask the right ?'s but I sure need help on this in simple terms.
    thanks trying
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. comp music with pic Sounds - Aka BeepMaster
    By flipper_md in forum Code Examples
    Last Post: - 20th September 2010, 07:04
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 02:44
