12F675 won't reprogram or erase
Results 1 to 17 of 17
    Sep 2003
    Vermont
    Let's try that again...
    If your code is evolving, you really should keep MCLR as a reset. The last programming action will be to flip the config fuse for the MCLR pin to become an input.
    Apr 2005
    Ahh that could make some sense then...If the last thing the programer does is flip the MCLR to being an input, that is why it could be crashing the MELABS programmer and corrupting the chip, but the chip's program seems to run fine.
    I will try using the MCLR as a reset and see what happens.
    Thanks again
    Apr 2005
    Making the MCLR a reset did the trick. Thanks to all for your thoughts
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 10:00
  2. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 04:58
  3. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 05:44
  4. serout out of order on 12F675
    By Ricardo in forum Serial
    Last Post: - 29th April 2008, 00:16
  5. 12F675 code sample
    By marad73 in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 13:53
