12F675 won't reprogram or erase
Results 1 to 17 of 17
    Sorry if i wouldn't be of help but, i believe that it doesn't worth too much to retrieve those value while those PIC are really cheap, just throw it away and use another one. The next time just read the value in, then write it down on a paper or use liquidpaper underneath your PIC and write value there.
    BUT Melanie already post something on that
    http://www.picbasic.co.uk/forum/show...84&postcount=2
    Apr 2005
    I appreciate the suggestion, I can throw away the chip and resolder a new one on, but I want to figure out how to keep this from happening again. I have killed 2 chips already and I know every other one I program will be dead unless I change something.
    Do you know if the MELABS programmer will automatically skip the OSCAL and BandGap settings? I need to program 1000s of these once i get this figured out and can't afford the time of writing down the OSCAL values of every chip.
    I am not even sure the OSCAL value being deleted is the problem, as I understand it I should still be able to reprogram the chip if that were the case and the internal oscillator would just be off by a little. At this point the programmer won't let me reprogram or erase the chip.
    OSCAL and bandgap are unimportant in making your PIC work.
    When you ERASe, all you ERASE is the program codespace and perhaps the EEPROM, the CONFIG settings are untouched.
    Just write a simple LED Blink Program for Internal Oscillator and Internal MCLR (ie MCLR as an I/O (Input) pin) and burn that into your PIC. You'll probably find it works.
    Apr 2005
    That's what I thought Melanie but when I tried that the chip locked up and won't allow for an erase or a reprogram.
    Should it matter that I have a 5k pull-down resistor on the MCLR pin since I am using it as an input? I think I also have 5k pull-downs on the ICSPData and ICSPCLK pins also.
    I'm starting to think this is more of a schematic issue then a config issue.
    Thanks again for any thoughts, they are much appreciated
    Programming in-circuit can be tricky is you have Vpp, data and clock pins tied to the application circuit.
    Programming voltage on /MCLR needs to rise fast enough to prevent the program counter from incrementing. If it does not rise fast enough, your code previously programmed into the device can start executing, and it screws up the whole process. In this case, you're trying to program a PIC that's already executing code, and is no longer in program mode.
    The internal RC osc makes the start-up process even faster, so it's even more critical for Vpp to rise fast.
    Try lifting the pull-down resistor you have on /MCLR, and make sure you have the programming clock & data pins disconnected from any external loads.
    External loads on data & clock pins will also screw up ICSP.
    That should allow you to re-program & erase in-circuit without any problems assuming the PIC isn't dead.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2005
    I'll give that a shot, but that basically means taking the pic out of the circuit using jumpers or I will loose 3 of the 6 GPIOs. I thought the pic should be able to handle this, I will try pulling the MCLR pull-down off first to see what that does and go from there. If the program programs the first time, should the clock and data pins really matter?
    Yes the clock & data pins definitely matter if you program in-circuit. A load on the clock pin in particular will really mess with timing.
    Read Microchips' DS91017B ICSP guide for a detailed explanation.
    -Bruce
    tech at rentron.com
    Sep 2003
    Vermont
    Talking
    Quote Originally Posted by Bruce
    I had the same issue rear it's ugly head some months back. If your code is evolving, you really should keep MCLR as a reset. The last programming action will be to flip the config fuse for the MCLR pin to become an input. If you place a 1 K resistor between the clock pin and the circuit it is attached to, this will help. Same with Data pin. For ICSP, I raise the pullup resistor to MCLR to 22K. It helps when your power supply is 2 to 3 volts and the programming power is 5 volts. If that's not enough, a schottky diode from B+ to the VDD pin will allow ICSP in a circuit that can't take 5 volts. I fried come 3 volt comm chips this way before the stupid light went off!
    I perconally traded the 12F series for the 16F690 in the 4 mm package. 18 GPIOs and 4 K of flash memory!Boy is this living!
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 11:00
  2. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  3. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  4. serout out of order on 12F675
    By Ricardo in forum Serial
    Last Post: - 29th April 2008, 01:16
  5. 12F675 code sample
    By marad73 in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 14:53
