Pager motor replacement
Results 1 to 13 of 13
    Sep 2003
    Vermont
    Default Pager motor replacement
    I have a product that uses a flat 12 mm diameter pager motor for silent signaling. I bought them surplus by the hundred, and as happens, they have run out. It ran at 3 volts, drawing 30 mA. Does anyone have a line on a similar part? I've seen some on line, but they draw 100 mils. Since the device is battery operated, I am trying to keep the draw as low as possible.
    I am surprised that there isn't some piezo counterpart that can do the same thing more efficiently without noise.
    Italy
    Ron,
    Type "pager vibrator" in Google.
    (Sorry if you get also the wrong vibrators).
    Example: (Pager vibrator!)
    http://www.73.com/a/0185.shtml
    The vibrator of a Motorola phone draws 180 mA at 3V.
    (The phone uses a 3.6V battery).
    Best regards,
    Luciano
    Sep 2003
    Vermont
    "The vibrator of a Motorola phone draws 180 mA at 3V."
    I need something under 80 mA @ 3 volts.
    Jan 2006
    Istanbul
    Lightbulb I can't believe it’s not butter!
    I am far away from this area but just as an idea why don't you look for tiny bobbin conductors?
    You know, the ones that create magnetic field and pushes a tiny metal pin forward and pulls backward hundreds of times in a second, and thus creates a vibration.
    I am sure the current is around your needs.
    Italy
    Ron,
    Check the page:
    Examples on that page:
    Type 1: (38,000 AVAILABLE)
    Operates on 1.3VDC@80MA. 7/8" x 3/8" x 1/4". Used in pagers, cell phones and vibrating batteries. 1-1/2" leads with mini 2 pin connector. $2.45 Ea/100, $1.95 Ea/1000. 93 in stock MC099
    Type 2:
    Low voltage, low current miniature vibrating motor. Operates on 1.5 - 3 VDC @ 62 mA. Tiny motor with offset weighted shaft is used in cell phones and pagers for vibrating alert signal. A removable black rubber boot surrounds the motor and provides a flat mounting surface. Without the rubber boot the motor measures 0.24" dia. x 0.5" long. The shaft and weight add an extra 0.21" to the overall length. Prepped with 0.42" long metal tabs. $1.95 Ea/100. ME235
    The info about the vibrator of a Motorola phone was just to help you
    when you search on the WEB. The vibrator was in a GSM phone I purchased
    back in the year 2001.
    Best regards,
    Luciano
    Sep 2003
    Vermont
    Thanks for the leads. It looks like Jameco has a good selection, but the current draw is still up there. Once again, I can't believe there isn't some other silent signalling device that is more efficient out there. If only small Piezos could be used for low frequency...
    Ron
