more than 8 bit for tables in flash (16F87x)
Results 1 to 14 of 14
    Hangover, Germany
    Default more than 8 bit for tables in flash (16F87x)
    Is there any way to store more than 8 bit (f.e. 10) in a 14-Bit-Word inside the flashmemory for tables ?
    All MPASM-directives only allow 8 Bit.
    Question Some explanation please ...
    Hi, Wumpus
    as we are in the PbP forum ... you could have a closer look to lookup2 and lookdown2 statements that deal with 16bits values ...
    a look to WRITECODE or READCODE could be valuable too ...
    That reminds me an old post from MEL about that subject ..." Playing with ... as a playground "
    that one also : http://www.pbpgroup.com/modules/wfse...p?articleid=10
    for MPASM exclusive use, two times the RETLW xx method seem to be unavoidable ... as W register is "only" 8 bits ...
    Feb 2003
    Salt Lake City, Utah USA
    Quote Originally Posted by BigWumpus
    maybe I am mistaken, but I thought the MPASM DATA directive gave you full access to store 14 bit numbers in code space ... see DATA in MPASM help topics
    Paul Borgmeier
    USA
    Hangover, Germany
    Unhappy
    READCODE ist used... it can read 14-Bit-Code into Word-Variables !
    (Writecode too!)
    But, you can't put 14-Bit-parameters in the flash.
    With the 18F... it will work (DW 1234h)
    I think somebody was pretty in love with the RETW-statement (or how else it is written).
    Like Ace said, LOOKUP2 will do the job, but it's a bit code heavy.
    This is a variant of the Strings idea that allows Very Large 14-bit WORD sized tables in code space.
    Address   VAR  WORD
    DataWord  VAR  WORD
    Offset    VAR  WORD
    GetAddress macro Label, Wout       ; Returns the Address of a Label as a Word
        CHK?RP Wout
        movlw low Label
        movwf Wout
        movlw High Label
        movwf Wout + 1
    '-----[The DATA table]--------------------------------------------------------
    DataTable
        DW  1234h, 2178h
    endasm
    '-----[Retrieve from DATA table]----------------------------------------------
    Offset = 1
    @  GetAddress   DataTable, _Address
    Address = Address + Offset
    ReadCODE  Address, DataWord
    LCDOUT  $FE, 1, HEX4 DataWord
    Or, if you only have One table to deal with, you could do it this way...
    DataWord  VAR  WORD
    Offset    VAR  WORD
    DataTable CON  EXT
    DataTable
        DW  1234h, 2178h
    endasm
    Offset = 1
    ReadCODE  (DataTable + Offset), DataWord
    Hangover, Germany
    Hi Darrel,
    Uuuuhhh......
    DW is not working for PIC16F.... it places a WORD packed in 2 BYTEs with a RETLW added.
    READCODE cannot adress the table direct, you have to use the macro, i guess. (but I will see what this CON EXT will be...)
    LOOKDOWN2 is ... I don't use it. My routine looks like this:
    NTC2Temp:
    @ SetI2CText _Tab_NTC
    I=0 ;Anfangstemperatur der Tabelle
    Gosub ReadWord ;Anfangsspannungswert ADC
    While DummyW ;solange die Tabelle noch nicht durch ist
    Dummy2W=DummyW:Gosub ReadWord
    For J=1 to 5
    If ADC_NTC<Dummy2W Then ;wenn Temperatur noch nicht gefunden
    Dummy2W=Dummy2W-(Dummy2W-DummyW)/(6-J):I=I+1
    Endif
    Next J
    Wend
    Dummy=I:Return
    ;Umrechnung NTC
    ;gemessener ADC-Wert auf Temperatur
    Tab_NTC:
    @ DW 879,852,821,786,747,704 ;0-25°C
    @ DW 659,612,564,516,468,419 ;30-55°C
    @ DW 375,338,303,270,239,211 ;60-85°C
    @ DW 187,166,147,130,116,103 ;90-115°C
    @ DW 92,82,73,65,58,52,47 ;120-150°C
    @ DW 0
    the datapoints (every 5 degrees) must be interpolated, so LOOKDOWN2 is not realy good to me.
    I think you've got it backwards.
    This is DW data compiled for a 16F877. It places each 14-bit word value in successive program word locations, which can then be read with READCODE.
    0286                  00490 DataTable
    0286   1234 2178 0001 00491     DW  1234h, 2178h, 0001h, 0781H
           0781
    This is the same data used in a LOOKUP2 statement.
                          00516         LU2RET?C        01234h
    0301   3434               M         retlw   low (01234h)
    0302   3412               M         retlw   high (01234h)
    0303   3400               M         retlw   0
                          00517         LU2RET?C        02178h
    0304   3478               M         retlw   low (02178h)
    0305   3421               M         retlw   high (02178h)
    0306   3400               M         retlw   0
                          00518         LU2RET?C        001h
    0307   3401               M         retlw   low (001h)
    0308   3400               M         retlw   high (001h)
    0309   3400               M         retlw   0
                          00519         LU2RET?C        00781h
    030A   3481               M         retlw   low (00781h)
    030B   3407               M         retlw   high (00781h)
    030C   3400               M         retlw   0
    It's the LOOKUP2 that puts the retlw's in there.
    As for the examples above. I have run the code. It works.
    You didn't include the ReadWord subroutine with your code so I can't tell how yours is tryng to read the NTC table.
    Hangover, Germany
    Quote Originally Posted by Darrel Taylor
           0781
    F***
    I use MP, not MPASM - Argh.
    MP compiles DW like this:
      4860					; D:\BFC\BFC200~1.BAS      	01508	    @ DW 942,915,884,848,808
      4861
      4862						ASM?
      4863	1282- 34AE 3403 3493 3403	 DW 942,915,884,848,808
    	1286- 3474 3403 3450 3403
    	128A- 3428 3403
      4864
      4865						ENDASM?
    OK, I had to use MPASM !
    Interesting... I didn't know it did that.
    Yet another reason to Not use PM. &nbsp;
    I guess I better update the <a href="http://www.picbasic.co.uk/forum/showthread.php?t=3891">EXT</a> thread to read MPASM only for the lookup Table. Thanks.
    Hangover, Germany
    OK,
    I switched to MPASM. Just look inside the Include-files of the MPASM to figure out the __config-command,
    comment it out in the Include-files of the PBP .... ;-(
    Then it works!
    I got 14-Bit-values in the flash ! This seems to be a weak part of MP ! ;-(
    I preffered to use MP, because the errors are located inside the code....
    That's an interesting finding dudes! As Darrel's said, yet another reason to not use PM!
    MPASM allow too much interesting feature that PM doesn't. Also, as a major reason of using it, it works with ALL PIC. But it also assume than the person back of the keyboard use/understand and want to use those feature. As assembler seems to be a common fear here... i doubt many will change their mind and use MPASM only for the reasons we stated.
    Anyways, thanks BigWumpus and Darrel.
    Oh Darrel, you finnally got me with the INCLUDE file. In conjuction with MESSG (for kinda help file) they're really usefull. Apologies!
    Hi Steve, that's Great!
    I guess I can check off your name in my list of people to convert to Include files.
    Let's see... 2 down, and 2,435 to go. Now we're cooking.
    LMAO! Well at least, there's some progress
  1. How do I use 10 bit A/D on 8 bit Pic? 12F675
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2020, 21:10
  2. Bits, Bytes Words and Arrays
    Last Post: - 14th June 2016, 08:55
  3. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
