Hi All
OK I imported the hex file into MPLAB and it generated the check sum fine. Sent the hex file plus the checksum to Microchip but it failed to pass. Heres the relevent part of the message from microchip:
The Programming Team advises the Checksum value submitted: "de73" does not match the actual Checksum value of the program.
The file submitted is in non-MPLAB standard format. Headers within the file are uniquely different than those produced by MPLAB and the memory map is incomplete.
Its generated using Microcode studio and PBP. I compile using the PBP compiler. Any clues whats wrong here?.
Cheers Pete
