Newbie - 16F628A and switch latching
Results 1 to 40 of 46
    Dec 2005
    Quote Originally Posted by malc-c
    It seems that its ignoring the "and" part of the statement
    Perhaps because you ignored the parentheses?
    Wink the last ...
    Hi, Malc
    try this:
    CMCON=7
    TRISB=%00000011 'set RB0 & 1 as input and the rest output
    SW1 var PORTB.0 'switch input pin 6 (RB0)
    SW2 var PORTB.1 'switch input pin 7 (RB1)
    LED1 var PORTB.4 'LED1 on pin 10 (RB4)
    LED2 var PORTB.5 'LED1 on pin 11 (RB5)
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    swset5=0 'Var swset is set low
    if SW1=0 then
    'If switch is LOW (Grounded) then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    loop: IF sw1=0 then loop 'wait for button release ... Yessss !!!
    GOTO jump
    Toggle Swset1 'change swset1 from 0 to 1
    pause 500 'debounce delay
    if SW2=0 then 'If switch is LOW (Grounded) then
    Toggle Swset2 'change swset2 from 0 to 1
    Jump:
    If Swset1=1 then 'if swset1 is 1
    high led1 'then turn on RB4 (and hence the LED)
    low led1 'else, LED is off
    If Swset2=1 then 'if swset2 is 1
    high led2 'then turn on RB5 (and hence the LED)
    low led2 'else, LED is off
    If swset1=1 and swset2=1 then
    toggle swset5
    Goto Main
    And now try to understand WHY !!!
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Acetronics
    Hi, Malc
    try this:
    Thanks, and yes it compiles OK and in tests works as required approx 70% (ie 7 out of 10) of the time. On three attepts LED2 remained lit, but its a lot better than my 0% success rate
    OK I'll have a go...
    CMCON=7
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    Sets up the PIC and the varibles
    if SW1=0 then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    If pin is grounded then check to see if varible bit swset5 is set high, and if so then swset 1,2 and 3 are all set low
    constantly loop round checking pin sw1 to see if grounded
    GOTO jump
    and if so, goto the section of the code labled jump....
    Jump:
    if the varibles swset 1 is high then turn on its corresponding LED, if low then turn off the LED, same thing for swset2
    toggle swset5
    Goto Main
    If swset1 and swset2 are both high then change the state of swset5 to high, which iwhen checked by the line above
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    resets swset1, swset2 and swset5 back to 0, and conversly all LEDs are turned off
    Checks sw2 and changes the state of swset2 (and thus LED2)
    Well how did I do ??
    malc-c's Avatar
    malc-c Guest
    Guys you crack me up... here am I trying to get technical and you guys are trying to put me mind off the subject by posting pictures of pussy on a public forum
    i hope you remember that you miss one word !
    The Melanie bad hair day is back!
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=445&d=1125012225">
    While we're at that... http://www.picbasic.co.uk/forum/showthread.php?t=2050
    malc-c's Avatar
    malc-c Guest
    That's a shame, either its my browser or the plug in, but I only get audio when viewing that clip
    With regards to the topic of this thread (Mel, I am trying to keep this on topic !) I hooked up a test track and placed a magnet on a loco to see how it worked, as I had been using magnets passing over the switches by hand to test the code.
    I don't know if it's due to the speed of the train (slower than my hand tests) but I got a 1 in 10 success rate of both LEDs being turned off when the train exited the siding
    The other question I have, is as I need 8 inputs and 8 outputs, can I use port A in the same way as port B. The thing that concerns me is the MCLR pin... do I have to do something to configure this as a normal input as I've read that this can cause problems if not treated right ??
    Cheers
    Malcolm
    (rapidly aging and going bald by pulling my hair out over this "issue")
    Wink Time to grow ...
    Hi, Malc
    Don't you think it would be the time to test the "BUTTON" statement, instead of " if SW1=0 then ..." ???
    May be we could also try more sophisticated debouncing ... but one thing after one !!!
    you want to play the " Speedy Gonzalez " ... no problem this side !!!
    PS: Try this : http://www.darreltaylor.com/files/ouchywhip.wav ...
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Addressing with Dip Switch or ???
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 16th September 2008, 13:19
  3. 16f628a wont wake up
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2008, 15:22
  4. SLEEP mode 16F628A
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 25th April 2006, 18:26
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 09:45
