Newbie - 16F628A and switch latching
Results 1 to 40 of 46
    Talking PbP is right
    YOUR Logic is wrong ...
    malc-c's Avatar
    malc-c Guest
    You ain't going to make this easy for me are you !
    A hint in the right direction would help !!
    malc-c's Avatar
    malc-c Guest
    OK following your advice I RTFM and it states
    If (B0 = 10) And (B1 = 20) Then loop
    So I applied the same logic to the code
    If swset1=1 and swset2=1 then occ
    occ:
    high led3
    ie if swset1 and swset2 both =1 then jump to occ, occ simply turns on LED3
    This didn't work. It seems that its ignoring the "and" part of the statement
    I mean this ain't exactly rocket (or should I say space shuttle ) science
    Dec 2005
    Quote Originally Posted by malc-c
    Perhaps because you ignored the parentheses?
    Wink the last ...
    Hi, Malc
    try this:
    CMCON=7
    TRISB=%00000011 'set RB0 & 1 as input and the rest output
    SW1 var PORTB.0 'switch input pin 6 (RB0)
    SW2 var PORTB.1 'switch input pin 7 (RB1)
    LED1 var PORTB.4 'LED1 on pin 10 (RB4)
    LED2 var PORTB.5 'LED1 on pin 11 (RB5)
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    swset5=0 'Var swset is set low
    if SW1=0 then
    'If switch is LOW (Grounded) then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    loop: IF sw1=0 then loop 'wait for button release ... Yessss !!!
    GOTO jump
    Toggle Swset1 'change swset1 from 0 to 1
    pause 500 'debounce delay
    if SW2=0 then 'If switch is LOW (Grounded) then
    Toggle Swset2 'change swset2 from 0 to 1
    Jump:
    If Swset1=1 then 'if swset1 is 1
    high led1 'then turn on RB4 (and hence the LED)
    low led1 'else, LED is off
    If Swset2=1 then 'if swset2 is 1
    high led2 'then turn on RB5 (and hence the LED)
    low led2 'else, LED is off
    toggle swset5
    Goto Main
    And now try to understand WHY !!!
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Acetronics
    Hi, Malc
    try this:
    Thanks, and yes it compiles OK and in tests works as required approx 70% (ie 7 out of 10) of the time. On three attepts LED2 remained lit, but its a lot better than my 0% success rate
    OK I'll have a go...
    CMCON=7
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    Sets up the PIC and the varibles
    if SW1=0 then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    If pin is grounded then check to see if varible bit swset5 is set high, and if so then swset 1,2 and 3 are all set low
    constantly loop round checking pin sw1 to see if grounded
    GOTO jump
    and if so, goto the section of the code labled jump....
    Jump:
    if the varibles swset 1 is high then turn on its corresponding LED, if low then turn off the LED, same thing for swset2
    toggle swset5
    Goto Main
    If swset1 and swset2 are both high then change the state of swset5 to high, which iwhen checked by the line above
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    resets swset1, swset2 and swset5 back to 0, and conversly all LEDs are turned off
    Checks sw2 and changes the state of swset2 (and thus LED2)
    Well how did I do ??
    malc-c's Avatar
    malc-c Guest
    Guys you crack me up... here am I trying to get technical and you guys are trying to put me mind off the subject by posting pictures of pussy on a public forum
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Addressing with Dip Switch or ???
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 16th September 2008, 12:19
  3. 16f628a wont wake up
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2008, 14:22
  4. SLEEP mode 16F628A
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 25th April 2006, 17:26
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 08:45
