Microcode studio can't find MPASM
Results 1 to 16 of 16
    Jun 2005
    Wisconsin
    Default Microcode studio can't find MPASM
    I'm trying to get MPASM working so I can utilize "Instant Interrupts."
    I installed MPLAB, checked "Use MPASM" in Microcode Studio. When I compile it searches for, and then can't find the assembler.
    Where am I going wrong here?
    BTW: I did make the path change in Environment Variables.
    Have you tried the Find Manually button?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2005
    Wisconsin
    I did, I get the same results. It searches for the folder and can't find it. Very odd.
    Click View, Compile and Program Options. Select the Assembler tab, then check Use MPASM.
    Now click the Find Manually button and select the directory you have MPLAB installed in.
    If you have it installed you should be able to locate it in the directory tree that pops up.
    OR. Are you saying that even after telling MCS where MPASM is located, it still returns the error?
    -Bruce
    tech at rentron.com
    Jun 2005
    Wisconsin
    That is the process I'm following. Everytime I try to compile it does a folder search and can't find the assembler.
    I've gone as far is just installing MPASM based on the MELABS instruction set and get the same thing.
    I know both are installed and working...not sure why microcode studio is doing this.
    That is an odd one.
    Have you verified where MPASMWIN.EXE is installed with Windows explorer, then checked this against the directory shown above the Find buttons on the assembler tab?
    Also try disabling Case Sensitivity. Do this on the MPASM assembler window check box & within MCS.
    -Bruce
    tech at rentron.com
    Feb 2005
    Saltburn by the Sea
    Select VIEW...COMPILE AND PROGRAM OPTIONS, then the asembler tab. Manually point it to MPASMWIN.EXE. If you are still having problems, you need to manually edit the registry and delete
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Assembler
    OR
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udio\Assembler
    if you are using the free version. After that, all should work well from within MCS
    Jun 2005
    Wisconsin
    I switched to CDLite and it "seems" to work. I get the popup window for MPASM, however it says I have errors.
    I have given up on Mircocode Studio since I have the free version and I'm using a 16F88 for this project.
    Nestyplus's Avatar
    Nestyplus Guest
    Default What's the latest version of Microcode Studio Plus
    Hi Guys,
    I just thought that this is the right segment to place my question. Although I did sent mail to mecanique but never got any reply.
    I'm using MCSP ver 2.3.0.0 which I got from melabs,
    My question is, is this still the latest version?
    Thanks in advance,
    Nesty
    Feb 2005
    Saltburn by the Sea
    You can always check if you have the latest version by selecting VIEW...ONLINE UPDATES.
    Nestyplus's Avatar
    Nestyplus Guest
    Quote Originally Posted by David Barker
    Hi David,
    I click on the View and choose online updates. It just show connecting on the lower right side bar for sometime and just disappears.
    Does that mean that it completed the update process? Or any pop out box coming off to give user a hint?
    Nesty
    Usually when there's some update available, there's a box who appear.
    I'm using MCSP and the version is actually 2.2.1.1. But by reading the post of our friend Nestyplus
    raise the same question... what is the latest version of MCSP?
    David?
    Talking Advertising ???
    Hi, Steve
    If you download the V 2.30 ... and install it, you'll get the 2.2.1.1 version ...
    too bad.
    "Les abrutis du marketing ont encore frappé" ...
    O.K no problem. BTW, what else we need in MCSP? Nothing else i guess. Even the bootloader files, once asked to David, are sent to your e-mail really fast so.
    Thanks Alain for double checking!
    Mar 2006
    Pennsylvania, USA.
    Question Same problem?
    I have the same problem with my Melabs USB programmer, MicroCode Studio searches but won't find it, even when I set it up manually. But it finds the assembler ok.
    Jun 2005
    Wisconsin
    I ended up moving back to microcode studio. The problem was the software was looking for mpasm.exe. However it should have been looking for mpasmwin.exe. I changed the registry and everything is functioning normally.
  1. Help setting up MPASM with MicroCode studio
    Last Post: - 23rd November 2008, 06:12
  2. Code Folding - Microcode Studio Wish
    By Rob in forum PBP Wish List
    Last Post: - 6th December 2007, 10:11
  3. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  4. MicroCode Studio Plus won't use mpasmwin
    By sjohansson in forum USB
    Last Post: - 4th January 2007, 23:10
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
