I can't believe it's impossible.. just post your code here first!
Well... keep a copy of the data in a register, and compare your new value in the loop to the existing register value.and how can i give signal for write data to eeprom before power supply off.
When and only when you have a new value, send the new value to the EEPROM, and update your register value too. Don't do it too often, as there is a limited number of cycles on that memory.
