save data in pic
Results 1 to 8 of 8
    johor,Malaysia
    Default save data in pic
    hello..
    i use pic16f84a for count something.. but if power supply off the data is lost.
    how can i save the data in pic and if i on the supply back the data will be use.
    can some one help me.
    New England
    Save the data to the on-board EEPROM - I think the F84 has 64 bytes.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    MELabs has sample code to do what Archilochus suggest here
    http://www.melabs.com/resources/samples/pbp/eeword.bas
    also check the samples file in your PBP folder for another example (ee.bas)
    Paul Borgmeier
    USA
    johor,Malaysia
    thankQ.
    i try this tonight
    and how can i give signal for write data to eeprom before power supply off.
    i cant save the data every time because my system loop forever
    Jan 2006
    there is a code example post by Melanie that addresses this as far as I remember. Do a quick search, youll find it.
    johor,Malaysia
    thankQ
    now i know how to read and write data to pic.
    i have anathor question.
    can i use interrupt and write progran to save data in pic..
    i try use interrupt and write program to write data to pic. but cant function..
    why..
    or i cant use write program if i use interrupt
    I can't believe it's impossible.. just post your code here first!
    Jul 2005
    Well... keep a copy of the data in a register, and compare your new value in the loop to the existing register value.
    When and only when you have a new value, send the new value to the EEPROM, and update your register value too. Don't do it too often, as there is a limited number of cycles on that memory.
  1. Going Loopy - How do i get my Loops sorted out ???
    By gtvmarty in forum mel PIC BASIC Pro
    Last Post: - 24th September 2009, 06:02
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  4. PIC to PIC Serial data using Cat5 cable
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 03:42
  5. Long varible strings
    By flashg in forum Serial
    Last Post: - 14th October 2006, 05:40
