Power drain, coin cell, while we're on the subject
Results 1 to 3 of 3
    Default Power drain, coin cell, while we're on the subject
    How does my math look here...
    I've got a circuit going for a keyfob type project, using a PIC16F688, internal clocks (both 32khz and 4mhz), RF transmitter from Rentron, an LED for display, 2032 type coin cell for power.
    PIC draws about 200nA sleeping using ULPWU module...
    PIC draws about 20uA total while check buttons once per second at 32khz internal...
    Circuit draws about 40mA (PIC plus transmitter plus an indicator LED) total while transmitting (figure one second per hour)...
    So,
    3,595,000 ms @ 200nA = 719,000,000 nAmS (nano-amp milli-seconds)
    3600ms @ 20,000 nA = 72,000,000 nAmS
    1000ms @ 40,000,000 nA = 40,000,000,000 nAmS
    Total = 40,791,000,000 nAmS (call it 41,000,000,000)
    divide by 3,600,000 (ms in an hour) = 11,330.83 nAh
    A good coin cell capacity is 200mAh = 200,000 uAh = 200,000,000 nAh
    200,000,000 nAh / 11330.83 nAh = 17,651 hours = 735 days = 2 years
    IF my circuit ran according to spec's, it should last 2 years on a cell, right?
    JDG
    Sep 2003
    Vermont
    Not exactly. The current drain of 40 mils will kill the battery much faster than the rated capacity. A 200 mil battery has a maximum drain rating of 15 mA/H. Over this, and the battery projected run time( and chemistry) is severly affected. A one second burn is actually a pretty long time for these critters. Using a sizeable cap will help, but size will probably be at a premium. Reducing on time is the best way to stay within specs.Look at a couple of months for a reliable estimate.
    Ron
    Default Coin cells
    The one second per hour was a quicky guesstimate on my part.
    10 characters @ 2400 baud once per hour is more like the real situation. Add that to some RF data-slicer set up time and the real amount would probably be more like 62ms (just a tad bit different from the one second I originally planned!).
    But the math...does it sound right, feel right? Theoretically of course...
    I don't really expect a coin cell to run for 2 years with my building ability...2-3-4 months would be just fine with me.
    JDG
  1. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
  5. PIC power drain
    By Ron Marcus in forum Off Topic
    Last Post: - 1st May 2006, 00:23
