help!!!!
Results 1 to 11 of 11
Thread: help!!!!
    Nov 2006
    does this mean a 100nanoFarad???
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    yes
    100 nF = 0.1 uF
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Nov 2006
    Thanks!!! BTW, I am trying to execute the code supplied in the PICBasic manual, but it doesn't seem to work.
    This is the code in the manual.
    B0 Var Byte
    scale Var Byte
    For scale = 1 To 255
    POT 0, scale, B0
    If (B0 > 253) Then calibrated
    Next scale
    Serout 2,0,[" Increase R or C.", 10,13]
    Stop
    calibrated:
    Serout 2,0,[" Scale= ",# scale, 10,13]
    This is my modified code:
    B0 var byte
    scale var byte
    LED var PORTB.1
    Potpin var PORTB.2
    for scale = 1 to 255
    LCDout $FE, 1, "calibrating", $FE, $C0, "Scale=", DEC scale, "B0=", DEC B0
    pot Potpin, scale, B0
    If (B0 > 253) then calibrated
    next scale
    Lcdout $FE, 1, "Increase R or C"
    stop
    calibrated:
    lcdout $FE, 1, "Scale=", scale
    As you can see, I have the pot connected to PORTB2.
    When I run the code, I can see the scale and B0 incrementing on the LCD, however, before B0 or scale reaches 255 it starts over from scale=0 & B0=0.
    Anyone have experience with this???
    I know it's possible to do this manually but I would like to do it with automation because I will need to calibrate the scale for several different pots in the future. Thanks!!!
    Jan 2006
    Istanbul
    At first glance, before other possibilities, "then calibrated" will work like GOTO; not like GOSUB.
    I would suggest that you use "calibrated" as a subroutine with a "return" and change all "then calibrated" to "then GOSUB calibrated".
    Then we can talk about the rest of the code.
    Nov 2006
    Thanks sayzer...I changed it to a gosub, and it freaked out because when it returns to the loop in still increments scale. So I tried goto calibrated and the LCD at least shows scale=, but it says "scale=r" WTF?
    Here's what I've got. BTW, thanks again for all of your help. I'm already miles ahead just from reading your posts.
    B0 var byte
    scale var byte
    LED var PORTB.1
    Potpin var PORTB.2
    If (B0 > 253) then
    goto calibrated
    Pause 1000
    next scale
    stop
    calibrated:
    Feb 2003
    Smile
    Possibly you want
    lcdout $FE, 1, "Scale=", DEC scale
    when you jump out, otherwise you get the ASCII equivalent of scale?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Nov 2006
    Talking
    doh! Thanks. Works great! Here's my final code for others to use as reference.
    B0 var byte
    scale var byte
    LED var PORTB.1
    Potpin var PORTB.2
    LCDout $FE, 1, "Wait for Calibration", $FE, $C0, "Current Scale=", DEC scale
    If (B0 > 253) then
    goto calibrated
    next scale
    stop
    calibrated:
    lcdout $FE, 1, "Use Scale=", DEC scale, $FE, $C0, "Have a nice day"
    high led
