Lowest voltage reading for a 1
Results 1 to 3 of 3
    Fayetteville Arkansas
    Default Lowest voltage reading for a 1
    I'm sure its in the data sheet somewhere but I can't seem to find it and my searches here hit so much stuff I still haven't found it. I'm using a 16F676 and reading a pin that is at .68 volts. What is the minimum voltage to read a 1? Even a reference to a page in the data sheet would be appriciated if this is too dumb a question. I seem to keep getting a zero.
    datasheet >> Electrical Specification >> table 12-6 DC Characteristic >> Parameter D040 and/or D040A
    Thank you Mr E. On the 676 it is actually Table 12.7. For some reason I thought the "Read" voltage was lower than the min operating voltage but I guess I was wrong._______I was definitely wrong! Thank you again Mr E. I will note this for future ref. It helps to know where to look. I sometimes tend to get lost in the data sheets.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
