Wrong values with COSINE!
Results 1 to 25 of 25
    Hangover, Germany
    Quote Originally Posted by Eng4444
    It's not at all as you thought dear Mr intelligent...
    By the way, thanks for your friendly reply! you're so much sociable and i think all your friends envie you
    there real problem is that i have tried your small equation... maybe befor you were born! but it didn't work at all..... i wonder what is the mistery and this is why i have asked a help....
    THIS EQUATION DOES NOT WORK... just try it and you will see! don't just "talk", try and tell me the result... are you getting real values???
    You don't know to whom you are talking - Stupid!
    I worked with computers long time before there was a PC. We worked with this cases with blinking lights and switches in front...
    I think, I know what bits look like and how to implement calculations ....
    And now - I'm sitting around, waiting for you and all your friends...
    But THEY will not help you!
    Eng4444's Avatar
    Eng4444 Guest
    Thumbs up Hey people.... thanks for your replies!:)
    Some of you are good ones and others are.... really bad! especially the one of lights and bulbs! haha.
    Dear Sirs,
    my question was simple and clear. You do not have to worry about what i am doing and why i did not use a table! you really have smart ideas there! but i just needed to see if there is one single HEAD of you able to solve this matter...
    i have 3 possibilities other than using TABLES.. but i still only have to solve this matter which is:
    i need to use the provided "cosine" question in the PicBasic Pro tutorial in order to get the usual answers... like cos 0 = 1 and cos 90 = 0 etc etc
    so just in case someone has a method, please say it and give the method otherwise, if it is only for dummie answers and stupidities, i have enough of IMPORTANT things to deal with and not obliged deal with bulbs and lights or anything else....
    By the way Mr Bulb, as long as I DUNNO WITH WHOM I AM TALKING.... why don't you show me what do you have INSIDE your brain? and not just what you USED to do in the past?
    maybe still dealing with bulbs till now?..........
    Come on people! the world has changed! lol
    Eng4444's Avatar
    Eng4444 Guest
    Default One more thing...
    thanks for:
    http://www.emesystems.com/BS2math3.htm#arcCos
    but in my application, i am not using x or y...
    i am just getting a phase shift from a Phase Locked-Loop, transforming this number to degree and then, i need the cosine of this number...
    All the problem is that "cosine" was made to give an answer in two's complement... and this is bad...... i need the normal answers...
    Italy
    From the link:
    Here is a simple demo program that illustrates the use of the SIN and COS on the BASIC Stamp. It steps through all the angles from 0 to 360. The angle is printed in degrees and the cosine and sine of the angle are printed as decimal numbers in the range of -1.00 to +1.00.
    Luciano
    Eng4444's Avatar
    Eng4444 Guest
    Exclamation OKay
    Thanks agains Luciano,
    but i really do not need them in this way... i don't mean to be rude or not caring but i really really do not need them like this..
  1. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 04:35
  2. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  3. Need help calculating OSC cap values
    Last Post: - 26th June 2008, 21:27
  4. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  5. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 12:46
