SED1335 320x240 graphic LCD
Results 1 to 17 of 17
    anyway, forget me on the previous, it will work yeah but not on the range you said... your method is good, keep it.
    Nice job you did! Any spare MAX232 output on your board?
    I'm not using any MAX232...?
    Why do you ask that?
    do a test... you'll see why sometime a spare MAX232 transmitter can be usefull. Place your voltmeter on a transmitter output.... set the transmitter input to GND, then to 5Volt. What do you get on your Voltmeter?
    Sorry Steve, no time for a test, especially when I don't know what you want me to test. The few hours I have are spent trying to finish this never-ending project.
    Default Correction To Code
    SendData:
    pinA0 = 0
    pinData = varByte
    pinWR = 0
    @ nop ' <--- ADD
    pinWR = 1
    SendCommand:
    pinA0 = 1
    pinData = varCommand
    pinWR = 0
    @ nop ' <--- ADD
    pinWR = 1
    The [@ NOP] turns out to be very important for high-speed display, it corrects a timing issue. Without it, there is a sort of 'echo' on the LCD when you display characters extremely fast (my initial tests were keyboard-type speeds).
    Is it still the game project we already talked about about a year ago but just grow with the age
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. SED1335 320x240 LCD
    By Demon in forum General
    Last Post: - 4th May 2006, 01:36
  5. graphic LCD sed1335
    By kk11 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 22:59
