SED1335 320x240 graphic LCD
Results 1 to 17 of 17
    For the contrast line, you don't need any driver between your PIC and the LCD, a simple resistor in serie will do the job.... let's say in a range of 500 ohms - 2K.
    Salut Steve! Donne-moi de tes nouvelles de ton voyage.
    How will you adjust the contrast using just a resistor?
    I wanted it so that both the contrast and backlight could be adjusted from 4 UP/DOWN buttons. Using transistors and HPWM was the cheapest way I could come up with. I now have a range of 256 steps for both controls.
    It will work the same way for contrast. You must keep your transistor for the backlight. For contrast, use HPWM and a in-serie resistor from your PIC to your LCD VO line. If this input don't need negative voltage, i have to work AS IS. Maybe you'll need to revert the values (0-255 to 255-0) but that's not a big deal.
    I used a 25K pot at first to get the contrast working:
    - Vss at one end with 0V.
    - Vout at the other end with -30V (built-in negative voltage).
    - V0 at the wiper.
    For a good contrast, the V0 wiper varied from -20V to -24V, with -22V for a good setting.
    Unhappy
    DOH! sorry... always read the Datasheet first, always read the schematic correctly too (Vout) Tabarnak!
    Where's the whip?
    maybe another solution... maybe, if not, broke my legs... again
    try it first. Place a 10K resistor between Vout and VO, on Vo place a 1K resistor in serie. Now send the other resistor end to 5 Volt. What happen with the contrast?
    If i'm not dumb it should do something. If so, in serie with the other 1K resistor, place a diode in serie. Anode to PIC, cathode to resistor end. Is it working? I have some doubt on that so far... -voltage against 0V and 5 Volt+diode plah plah. I really need to return on a bench... feel rusty here!
    $99 USD per LCD.
    I can't afford to do magic shows with these suckers.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. SED1335 320x240 LCD
    By Demon in forum General
    Last Post: - 4th May 2006, 01:36
  5. graphic LCD sed1335
    By kk11 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 22:59
