HWPWM and 4 motors
Results 1 to 9 of 9
    At least, 4 possible solutions
    1. Use 4 different PIC like 12F683 wich have PWM, ADC, and comparator available
    2. Use one pic but no HPWM. You do your PWM signal using an TIMER interrupt. Once in the interrupt routine you just play with the duty delay of each outputs. Depending the frequency... it could work really well
    3. Use external DAC converter OR digital pots.
    4. Search for another PIC that allow 4 independant PWM... if it exist.
    fanie's Avatar
    fanie Guest
    Have a look at the 16F684...
    Cool Muti_SPWM
    Hi Nick,
    Taylor made to your request, 2 years in advance.
    Multiple Slow speed Software PWM
    http://www.pbpgroup.com/modules/wfse...p?articleid=12
    Macgman2000's Avatar
    Macgman2000 Guest
    The 16F684 is a 1/2 or full bridge driver. It will only output PWM on 2 ports and give steering logic to activate an H-bridge (FWD / REV). Has anyone used it to put out 4 PWM signals? I don't think it is possible per spec sheet.
    Best Regards,
    Nick
    You are correct!
    You can only get 2 PWM's from it.
    The ECCP does have several outputs. But, they can not be configured to output different frequencies or PWM dutycycles.
    fanie's Avatar
    fanie Guest
    If you want more PWM's have a look at the 18F2431 - sports up to 4 PWM's with complimentary outputs...
    Now that's a Cool chip.
    I can't believe I haven't seen it before.
    Wow, all those PWM's, and Capture channels.
    Built in Quadrature Encoder Interface.
    Super Fast A/D.
    And everything else a good 18F would have.
    Geez, where have I been..
    Thanks fanie!
