HPWM and A to D interaction question 18F252
Results 1 to 8 of 8
    ARRRRRRRRRRGHHH invaders from the other camp. Hi Fanie, welcome here!
    HPWM or PWM module can't interfer with a/d. BUT it could have something to do with the CCP2 trigger if there's something bad in the CCP2CON<3:0> register setting. Refer to section 17.5 of datasheet. But if it was the problem... i doubt the PWM will work anyways.
    BUT as we didn't see any code line and schematic, it sounds more like a hardware problem... maybe a overloaded Psu too!
    fanie's Avatar
    fanie Guest
    Eh Steve !
    Thanks for the optimistic welcome, gee whiz... just thought I'd pop in to see if you guys need any help here but everything seems under control... between you and Nav anyways. Well, kind of.
    As far as I remember the PWM (after defined CCP2CON) I had to do after the setup code, ie as part of the program (doesn't sound right). In my case it wouldn't run on it's own as it should and I got funny things happening. No PSU probs...
    tcbcats - upload a bit of code... maybe someone would spot something.
    Feb 2005
    Kolkata-India
    Default Have you tried changing the sampling frequency?
    According to you when your CCP pin is floating (there is no load connected) you are experiencing the same problem. This perhaps indicates that your HPWM is not playing anything with the VDD line as this is Vref as well (I assume). A schematic post (with layout if possible) would be appreciated. By that time try playing with the sampling frequency (use the RC clock) and a bit more time for the sampling.
    Sougata
    Dec 2003
    San Diego
    Smile Got it working.... with ADCIN
    I did not find the problem but did get the code working.
    I was setting up the A to D with the direct registers and had the setup wrong.
    I just changed the code to use the ADCIN command and all is now working.
    Something was messed up where I was reading the A to D justified register into a variable word using. .highbyte and. .Lowbyte
    Yes this is on a breadboard but the results are now very stable as expected.
    Thanks all…
    tcbcats
