how to pause 10us
Results 1 to 5 of 5
    johor,Malaysia
    Default how to pause 10us
    hello
    i want pause 10us
    can some one help me
    realy need help
    Hangover, Germany
    Pauseus 10 ???
    Caution... The minimum value for PauseUS is 24uS at 4MHz clock. You have to have a clock around 10MHz or greater before you can achieve 10uS.
    You can use a series of @ NOP statements, each of which will delay 1uS at 4MHz.
    johor,Malaysia
    thank for help..
    melanie..
    can i use this for transmit the signal for ultra sonic sensor
    start:
    high portb.0
    low portb.1
    pauseus 10
    low portb.0
    high portb.1
    pauseus 10
    goto start
    NOP?
    i dont know.
    can u tell me
    Macgman2000's Avatar
    Macgman2000 Guest
    I don't mean to sound snippy, but do you have a PICBASIC PRO manual? You can view it on line if not. You have several options, the syntax is easy for your application.
    1). write inline assembly in the middle of PicBasic for the tx routine
    2). use a for loop to toggle through your tx routine X-number of times (number of cycles) using the pauseus running at > 10Mhz clock.
    3). write it all in assembly and run whatever clock frequency you want.
    Best Regards,
    Nick
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 11:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
