Sensor reading Program Help Required
Results 1 to 4 of 4
    I made a lot of assumptions since you don't mention the PIC type, osc speed, etc, but something like this should work.
        y    var byte
        x    var byte
        Loop VAR BYTE       ' used for delay loop
        Time CON 25         ' 60 x 25uS = 1500 uS for PAUSEUS loop
        Sensor1 VAR PORTB.7 ' sensor 1 input
        Sensor2 VAR PORTB.6 ' sensor 2 input
        PORTB.4 = 0       ' ununsed output
        PORTB.5 = 0       ' unused output
        TRISB = %11000000 ' RB6, RB7 sensor inputs, rest outputs
        OPTION_REG = 0  ' internal pull-ups off
        on Interrupt Goto IntService ' where to go on interrupt
        INTCON = %10001000       ' RB port change interrupt enabled
    Start:
        for x= 0 to 20
          for y=1 to 50
            PORTB = %00001010
              for Loop = 0 TO 59
               pauseus Time        ' pause 25uS per pass allowing faster interrupt
              next Loop            ' service time (assumes 4MHz osc)
            PORTB = %00001001
              for Loop = 0 TO 59
               pauseus Time
              next Loop
            PORTB = %00000101
              for Loop = 0 TO 59
               pauseus Time
              next Loop
            PORTB = %00000110
              for Loop = 0 TO 59
               pauseus Time
              next Loop
          next y
        next x
        GOTO Start ' Assumption on my part here?
    IntService:   ' Object detected by sensors
       Disable
       while (Sensor1=1) AND (Sensor2=1) ' stay here until both return low
       ' do something useful here
       wend
       INTCON.0 = 0  ' clear RB port change interrupt flag bit
       resume
       Enable        ' return after processing object detection
    Using RB6 & RB7 as sensor inputs you could have the interrupt generated on change.
    The Loop with pauseus cuts down on the time it takes for the polled BASIC interrupt to be serviced.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2006
    Exclamation theres a bit change now
    Hi Bruce
    thanks for that tremendous help. I perhaps forgot to tell u that much detail. here is the detail you wanted:
    Im using PIC16F84A with 4MHz crystal oscillator. And one more thing that i wanted to tell you is this that im using the DC motor (PWM control method) now instead of using stepper motors. So please tell me in the perspective of the DC motors. I shall be thankful to u for this.
    One more favor that i want from u is this that please tell me any coding through which i can control the revolutions of the DC motor. I mean i want to program my motor in such a way that it takes 3 revoultions with a defined speed and then stops and then take 4 revolutions and then stops again and so on.
    I shall be thankful to u for this act of kindness.
    Take carez
    Good Bye!
    LETS MOVE TOWARDS SOMETHING PRACTICAL---
    Review some of the Microchip DC motor control application notes here:
    http://www.microchip.com/stellent/id...1505&pageId=64
    Decide on the components you plan to use, put together a schematic, then
    take a shot at putting together your code to make it work.
    If you have problems with a particular code segment, motor drive circuit, etc,
    then post what you have done so far here.
    People here are more than willing to offer assistance, but most prefer to see
    that you have made an effort to solve the problem yourself first.
    There are several threads on this forum as well on DC motor control. Use the
    search button for DC Motor Control.
    -Bruce
    tech at rentron.com
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
