Time between interupts
Results 1 to 3 of 3
    Apr 2005
    Default Time between interupts
    I'm looking for a creative solution or any ideas for a method of measuring the time between to rising edge interrupts using only pin B0 of an 877a chip.
    I've basically got an external PWM signal that I am monitoring using a B0 pin interupt using the "Instant Interrupts" that Daryl created (Great by the way). The interupt is triggered on the rising edge and processes a small subroutine before exiting the interrupt. After exiting the interupt the PIC processes other code while it looks for the next rising interupt. The interupt and subroutine work great, but I need to know how often the interrupt occurs.
    I have not tried this yet, but I was thinking of using the COUNT command to count the number of pulses over a certain period of time, but I am not sure if the COUNT command will work and not be effected by the interrupt.
    I apreciate any input.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    If you like Darrel's Instant Interrupts, you also might want to try his routines to measure time between events. His post for that is here
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    If your time is going to be greater than 2^16 instruction, you may need to modify his code to count overflows.
    Paul Borgmeier
    USA
    Apr 2005
    Thats pretty sweet, I'll have to see if I can get that one to work. It sounds like it will do exactly what I need and much more accurately.
  1. Help! My 'interupt', erhm ...only interupts the one time?!!!
    Last Post: - 2nd November 2009, 13:49
  2. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  3. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
