7 segments clock
Results 1 to 6 of 6
    if it's only a simple clock, i don't know why you should need anything else than One pic and few transistor to do a multiplexed display.
    something to play around of => http://www.picbasic.co.uk/forum/show...quency+counter
    Sep 2003
    INDIA
    Default Rtc ?
    Would there be a RTC in it ?.
    I had made something using a RTC.
    regards
    Charudatt
    4Lewis's Avatar
    4Lewis Guest
    Red face LED Clock
    Trying to make a clock that outputs to LEDs, (NOT TO A DISPLAY!) Are their any suggestions to how to start this type of project? Do I need a clock or timer circuit to hook up to my PIC to figure out proper timing. Please help/suggest. All the best. - Lewis
    Thank's to all for the answers.
    I made a 4 digits display using 7 segmentes C.C., I'm trying to use a rtc, ds1302. In the future I will add a temperature sensor. I'm trying to learn how to write in pbasic, but it takes long time, is a long process. I'm playing with with differents components like 7 Seg, led's, sensors (light, distance, etc), i have also a lot of 5x7 and 8x8 dot matrix led that i would like to drive them.
    thanks.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  4. adding with 7 segments
    Last Post: - 28th November 2007, 23:51
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
