Newbie problems, Can someone help me..
Results 1 to 3 of 3
    vaidyasp1's Avatar
    vaidyasp1 Guest
    Default Newbie problems, Can someone help me..
    hi,
    I am working with two controllers 16f84 and 18f4520. I use my picbasic pro compiler to compile following program. It works fine with 16f84 but does not work with 18f4520. For 18f4520 i have connected just vdd and vss pins. Is the circuit fine??
    I also get a warning 230 while compiling the code for 18f4520. I think that is for the configuration bits.
    I think my controller is not running at all. Because it cannot have the clock. so, i want to know the configuration bit settings for internal 8Mhz rc oscillator. So, how can i configure them. I use the EPIC programmer given from melabs. So, what should be the option for internal rc oscillator??
    whether it should be INTRC Clockout or INTRC??
    My very simple code was as below....
    -----------------------------code-----------------------------------
    OUTPUT PORTA.0
    loop: High 0 ' Turn on LED connected to PORTB.0
    porta.0 =0
    high portb.3
    Pause 500 ' Delay for .5 seconds
    Low 0 ' Turn off LED connected to PORTB.0
    low portb.3
    porta.0=1
    Goto loop ' Go back to loop and blink LED forever
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Oops - wrong button
    Paul
    All about 'How to set config fuses http://www.picbasic.co.uk/forum/showthread.php?t=543
    Also you'll need to disable all analog stuff on PORTA & PORTB (Comparator and A/D converter) : Datasheet Section 19.0 and 20.0
    AND finnally you'll need to configure the internal oscillator speed as the default is 1MHZ : OSCCON register Section 2.6
  1. Problems with U2 programmer C30 compiled code
    By minimii in forum Off Topic
    Last Post: - 5th November 2009, 10:43
  2. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
  3. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
  4. Goto inside a gosub??? Problems...
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 13th October 2005, 13:17
  5. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 22:45
