UArt question
Results 1 to 6 of 6
Thread: UArt question
    smeet's Avatar
    smeet Guest
    hi thanks a lot... ill look into that... I had another question.. Do u recommend using Manchester coding for RF communication... My PIC output is connected to a transmitter at 418 Mhz ...
    I need a range of around 300 feet..
    Default Manchester
    Yes, absolutely do use manchester encoding. This came up a number of times and you will find alot of answers if you do a search.
    smeet's Avatar
    smeet Guest
    Default re:
    I am trying to use Hserout with manchester coding.. however I have this problem... DOes Hserout support 16 bits or do I need to specify IBIN16 before the variable...
    I could not implement the Instant interrupts as I have never used them before and I need to submit my project by tom...
    Any help from you will be appreciated thanks a lot
    Hserout is 8-bit command.
    If you want to send out 16-bit wide variable you have to send it like 2 bytes as
    Hserout [mybyte.lowbyte, mybyte.highbyte]
    or as an array. I think better is the first way.
    All are in the manual of the compiler.
  1. Bootloader for 16f87/88 that doesn't use UART
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 17:35
  2. Super easy 18F print strings to UART
    Last Post: - 26th August 2007, 23:19
  3. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
  5. External UART IC
    By Terry in forum General
    Last Post: - 22nd December 2005, 18:01
