SPI on a pic without hardware SPI?
Results 1 to 4 of 4
    Apr 2005
    Default SPI on a pic without hardware SPI?
    Does anyone know if the Shiftout command is a software version of SPI and if it can be used to make SPI eeprom and other devices work on microchips that don't specifically have hardware SPI?
    Yes. Look at a few of the MeLabs examples using shiftout/shiftin for SPI EEPROM.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2003
    Vermont
    Quote Originally Posted by modifyit
    Yep. I've used it to communicate with SD cards, ALFAT SD and SPI peripherals without hardware implementation. Pay attention to clock polarity, and if the device validates the data before the clock change,or after. The only down side, besides speed, is you can't shiftin data while you're shifting out. Many devices send data at the same time you are shifting data into them. You will also need to dedicate a pin to select the device before a transfer.
    Apr 2005
    Great thanks for the confirmation
  1. SPI Communication between two pic 16f877
    By anti83 in forum Serial
    Last Post: - 5th July 2008, 22:06
  2. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  3. Hardware SPI with MAX3111E
    By KHsu in forum mel PIC BASIC Pro
    Last Post: - 8th August 2007, 02:42
  4. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 20:17
  5. SPI PIC to PIC Bi-Directional Communication
    By CocaColaKid in forum Serial
    Last Post: - 23rd December 2006, 23:44
