Options_reg
Results 1 to 2 of 2
Thread: Options_reg
    paul.mcallister's Avatar
    paul.mcallister Guest
    Smile Options_reg
    Hi, I am trying to use the OPTIONS_REG directive to turn on PortB pull up resistors for a 16F876 but I can't find reference to it in the PicPro manual.
    Browsing the Pic data sheets sugests that this directive does other things as well.
    Could some one give me the correct syntax for turning on the pull up resistors, and if possible where I can read about it in the PicPro manual
    Thanks, Paul
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    See section 2.2.2.2 of the 16F876 data sheet (this is a must read)
    Just add
    OPTION_REG.7 = 0 'turns on weak pull-ups
    or
    OPTION_REG.7 = 1 ' turns off weak pull-ups
    near the top of your code.
    OPTION_REG is one of many Special Function Registers that can be accessed directly. Do not leave home without the PBP manual and the data sheet for your PIC!
    Good Luck,
    Paul Borgmeier
    USA
