Low Voltage Detection - 16F628A
Results 1 to 13 of 13
    a regular 16F628, depending of the crystal speed, is suppose to work from 3V to 5.5V. Detecting a 3V may work great or not. What i'll personnaly do is to use the 16LF628 wich work down to 2V. That's my own opinion.
    What i usually do, and some may have another opinion, is to use an LF serie and a LDO voltage regulator. This give me a stable voltage reference to compare against the battery voltage. That way it work.
    One way to do it...
    Datasheet section 9.1 use mode 101 (one comparator)
    Poll C2OUT bit of CMCON
    OR Interrupt
    Enable Comparator interrupt (see PIE1 register 4.2.2.4)
    your code.
    Interrupt routine
    Blink your LED
    Clear Comparator interrupt flag CMIF (PIR1 register 4.2.2.5)
    Resume Interrupt.
    Without any voltage regulator it's not impossible but you need a stable voltage reference... i remind one of my bench stupid idea in the past : use an I/O to supply a Resistor + Zener Diode for the voltage reference... worked. But as Zener diode need few mA to work properly... it's not suitable for a battery powered system... IMHO
    Bombay, India
    Default Take a look at
    Take a look at the MC34064 low voltage detector. Connect this to a port pin and check the pin to decide if you want to blink the LED
    Jerson
    Use the 16F628A's COMPARATORS, this is exactly what they can be used for...
    Many years ago, I did a Comparator tutorial on the piclist, a link to the archive where it can be found is here...
    http://list.picbasic.com/forum/messa...tml?1020960642
    By configuring the internal Voltage Reference Module (Datasheet secion 11), you can detect voltages as low as around 208mV, by using two Resistors (Potential Divider from 5v rail) as external Reference, you can get even lower. See the Datasheet (Table 17-2) for the Comparator Specification for exactly how low. Theoretically by setting the Reference to 0v you might be able to detect a positive going voltage as low as 10mV, though I haven't tried that.
    Talking Miracle !!!
    Quote Originally Posted by Jerson
    Jerson
    Hi, Jerson
    As the 34064 detects 4.65v ... how do you do this kind of miracle ???
    Bombay, India
    Default No miracle here.
    Hi Alain
    Since Charudutt did not specify how low is low voltage for him, I assumed. Anyway, I have a similar app where I use 6V for supply and 4.65 is low enough for the circuit to stop operating correctly.
    Jerson
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  2. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 19:29
