PORTA.PinNo = 1 ' problem
Results 1 to 4 of 4
    frank small's Avatar
    frank small Guest
    Default PORTA.PinNo = 1 ' problem
    Can anyone tell me what is wrong with this and how to get round it?
    I am using VB to control the pins of a pic over a serial link and I am just testing at the moment
    by turning on and off paticular pins
    Test code is something like this
    DIM PinNo AS BYTE
    DIM PinState AS BIT
    PinState = True
    LET PinNo =5
    If PinState = 1 then
    PORTA.PinNo = 0 ' problem
    The compiler has a problem with
    PORTA.PinNo = 1 or PORTA.PinNo = 0
    though no problem with
    PORTA.5 = 1
    Any suggestions please
    Frank
    Portx.myvariable is not a valid PBP statement.
    Please do a search for...
    pin* AND addressing
    ...as this topic comes up regularly in various guises.
    frank small Guest
    Default Thanks
    Many thanks ,Melanie
    Frank
    frank small Guest
    Hi Melanie
    Looked at all the info as you suggested and it made sense
    However I cannot get porta.0(x) = 1 to compile
    Here is an example of one of my attempts
    In other attempts I used [x] instead of (x) and in frustration
    I declared Porta.0as an array but of course that did not work
    'Configure
    DEVICE = 16F877
    XTAL = 20
    Dim x as byte
    x=1
    porta.0(x) = 1
    What am I doing wrong?
    Frank
  1. Variable in array
    By Gusse in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 20:46
  2. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  3. HSERIN doesn´t work
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 29th July 2007, 15:23
  4. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 16:35
  5. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 20:16
