Extending Temperature sensor
Results 1 to 7 of 7
    Hangover, Germany
    Try this:
    AD595 mit an Type K Thermocouple and maybe 12V voltage,
    a very good voltage-divider to convert 10V to 5V ;-),
    a very good 5V-reference for the AD-Part of the PIC,
    10 Bit resolution,
    a table of the real temperature compared to the voltage ...
    look inside the datasheet !
    I've made an Excel-sheet of the temperature vs. voltage and so I got the %-error for every 100°. So I could interpolate the real temperate.
    Pinckney, Michigan
    The Maxim MAX6675 part will work fine for you. It's a K-type to SPI interface chip, good to 1024 deg C. I've used it, works good.
    sianjohn's Avatar
    sianjohn Guest
    Wink re extending temp
    Thank you for assistance i will try this chip i'll wait for the parts to arrive...
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Precision Temperature Sensor
    By Normnet in forum Off Topic
    Last Post: - 8th March 2010, 15:48
  3. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 14:51
  4. Precise temperature sensor
    By Christopher4187 in forum Off Topic
    Last Post: - 7th June 2006, 19:39
  5. read temperature sensor
    By breeno in forum General
    Last Post: - 10th January 2005, 07:04
