Extending Temperature sensor
Results 1 to 7 of 7
    sianjohn's Avatar
    sianjohn Guest
    Smile re extending temp DS1820
    Thanks for the replies you"ve made it is right that i plan to use d1820...but i got problem when i verify its datasheet it is too low for the project...
    My plan is to make temperature sensor for my wife gasrange using 16f887 triac and nichrome to make the heat stable using +/- varying of electric heater and gas, any suggestion about this...
    please do... i am very eager to know all of your idea that will help this project...
    Angelo
    Hangover, Germany
    Try this:
    AD595 mit an Type K Thermocouple and maybe 12V voltage,
    a very good voltage-divider to convert 10V to 5V ;-),
    a very good 5V-reference for the AD-Part of the PIC,
    10 Bit resolution,
    a table of the real temperature compared to the voltage ...
    look inside the datasheet !
    I've made an Excel-sheet of the temperature vs. voltage and so I got the %-error for every 100°. So I could interpolate the real temperate.
    Pinckney, Michigan
    The Maxim MAX6675 part will work fine for you. It's a K-type to SPI interface chip, good to 1024 deg C. I've used it, works good.
    sianjohn's Avatar
    sianjohn Guest
    Wink re extending temp
    Thank you for assistance i will try this chip i'll wait for the parts to arrive...
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Precision Temperature Sensor
    By Normnet in forum Off Topic
    Last Post: - 8th March 2010, 14:48
  3. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 13:51
  4. Precise temperature sensor
    By Christopher4187 in forum Off Topic
    Last Post: - 7th June 2006, 18:39
  5. read temperature sensor
    By breeno in forum General
    Last Post: - 10th January 2005, 06:04
