Controlling A Digital Pot
Results 1 to 8 of 8
    Apr 2006
    Default Controlling A Digital Pot
    I was wondering if someone could refer me to a basic schematic and code for controlling a digital pot with the pic. I am using the pic18F452 with pbp 2.46
    Thanks for any help.
    Tony
    Any plan on your digital pot? Microchipone or else... it will be handy for us to know at least the pot you want to play with...
    Apr 2006
    I am thinking about using MCP41100-I/P IC
    http://www.jameco.com/wcsstore/Jamec.../241787MCH.pdf
    What I'd like to do is control the digital pot with the pic. The pic will be interfaced with an analog sensor, the pic will read the sensor (using ADCIN) and based on the the result of the sensor the pic will respond by making changes to the digital pot.
    What I'm wondering is how to get the code going. I guess it would start like this:
    ADCIN sensor input pin, result
    result = digital pot control
    As my hands can't place anything on a board now, i'll just give you some tips ... typing on a keyboard is hard enough:
    1. You'll need 3 I/O (CS,SCK,SI)
    2. Read the datasheet Section 5.0 (Few Microchips datasheet are fairly well explain, that's one of those. Really easy)
    3. PBP manual under the SHIFTOUT statement.
    No specific schematic, plug and play. Just check the POT limitation first about max current and all the plah plah plah and you shouldn't have too much problem.
    Also take into account that a digital pot never reaches absolute zero. Always do show a minimum resistance. If you can tolerate it then go use it.
    Apr 2006
    Thanks. So this would be using the Serial port of the digital pot?
    Thanks again,
    Tony
  1. Digital Pot
    Last Post: - 3rd January 2012, 07:54
  2. Controlling a MCP4162 Digital Pot
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 6th February 2011, 18:51
  3. Digital Pot Advice
    Last Post: - 22nd October 2007, 20:38
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. Serial control of a digital pot?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2006, 23:49
