NMEA checksum
Results 1 to 2 of 2
Thread: NMEA checksum
    Sep 2003
    Vermont
    Default NMEA checksum
    I need to send a serial string to a GPS device. It needs to be followed by a crc two digit checksum which is an XORing of the data field. How would I do this without having to check it in advance? Using lookup and send them out one at a time after XORing with the previous?
    Ron
    eoasap's Avatar
    eoasap Guest
    Hi (again) Ron!
    Do you need to change it in code? or are you just using it to send a command to change the default baud rate? i'm not sure how to do it in code, but i know the checksums for different bauds if it'll help ?
  1. NMEA CheckSum Routine
    By Tom Gonser in forum Code Examples
    Last Post: - 6th June 2015, 22:24
  2. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 22:36
  3. Checksum
    Last Post: - 24th October 2009, 04:09
  4. Creating Checksum in PBP
    Last Post: - 16th March 2005, 04:49
  5. Checksum problem!
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:21
