High resolution ADC
Results 1 to 3 of 3
    vsingh's Avatar
    vsingh Guest
    Default High resolution ADC
    Does anybody have experience (and code) for high res ADCs ? Need some thing either 16 or 19 bit that is easy to interface to a PIC876.
    Everything I can find is either 12 bit or uses the internal 10 bit ADC
    - V.
    Cirrus Logic CS5531 Series (inc 5532, 5533, 5534).
    16 and 24-bit ADC's. Built-in integral gain amplifier (1x-64x) and noise rejection nicely dispenses with lots of external conditioning and amplification circuitry ensuring minimum component count. I2C easily interfaces with PIC's and PBP. Follow the instructions in the comprehensive datasheet for setup, configuration and use.
    Download Datasheet here...
    http://www.cirrus.com/en/pubs/proDatasheet/cs5531-5.pdf
    Find overview, links to errata and other data from here...
    http://www.cirrus.com/en/products/pro/detail/P95.html
    Melanie
    massquip's Avatar
    massquip Guest
    Thumbs up
    hi there can supply you with picbasic pro code for the ad7715 16 bit a/d converter
    what do you want to measure?
    send me your email address
    email me at [email protected]
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 16:23
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
  5. Replies: 2
    Last Post: - 17th February 2006, 10:52
