help with 16f628a
Results 1 to 4 of 4
    thalia's Avatar
    thalia Guest
    Smile if this is too much to ask, just........
    if this is too much to ask, just........please show me how to read/write to the non volatile part of the pic 16f628a memory.
    how to rear a button from a port
    how to output a high/low to a port
    how to use the timer
    all of this to the pic16f628a
    please, please.
    thanks in advance for any an all your help, and for taking time of your busy schedule to read my questions and requests
    Here is some code to get you started...
    	@ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT
    	@ DEVICE pic16F628A, WDT_ON
    	@ DEVICE pic16F628A, PWRT_ON
    	@ DEVICE pic16F628A, MCLR_OFF
    	@ DEVICE pic16F628A, BOD_ON
    	@ DEVICE pic16F628A, LVP_OFF
    	@ DEVICE pic16F628A, CPD_OFF
    	@ DEVICE pic16F628A, PROTECT_OFF
    	ButtonA var PortA.0	' Button connected between PIC pin and Vss
    				' Resistor (10K) connected between PIC pin and Vdd
    	LEDA var PortA.1	' LED connected between Vdd and PIC pin
    				' via 330R Resistor
    				' Anode end of LED towards Vdd and Kathode to PIC pin
    	TRISA=%00000001
    	CMCON=%00000111
    Loop:
    	If ButtonA=0 then
    		Low LEDA
    		High LEDA
    	Goto Loop
    Press the Button and LED will light. Release the Button and the LED will go out.
    I have you shown with this piece of code how to read an INPUT from a press-button, and how to OUTPUT to control an LED. The @ DEVICE statements will configure your PIC for internal Oscillator and internal MCLR so it will work the moment you apply power to it.
    Look-up each command/instruction I have used either in the PICBasicPro Manual or the Datasheet.
    It is now UP TO YOU to logically design how your program will work. The PBP Manual and the PICs Datasheet are essential reading.
    thalia's Avatar
    thalia Guest
    Smile it's working....it's working
    After a couple of days of working NON stop (and no sleep) I finally finished my project, IT's working, It's working.......thanks a lot for the help, it was fun to learn.
    the core of the project was to activate a count down timer when ONE or TWO push buttons are pressed, each one should have it's own independent time (the amount of time can be change by the user using the same TWO push buttons right after power on and after the user quit pressing for adjusment or if (s)he doesn't press them at all, then the new time is stored in the eeprom memory), further more every time the button(s) is(are) pressed it will increment the time left and this could happend at any time and many times, the time left for each button has to be displayed in four 7-segments display LEDs with MM:SS format if only one button is pressed of one of the two has run out of time, and in M1:M2 if the two have time left. also a count of every push has to be stored in EEPROM memory to be displayed at will by the user, at the power up of the circuit (either the user adjust the time per push, or want to know the amount of pushes has been so far), and finally while there is time left a relay stays ON to activate an external device (ONE PER EACH OF THE TWO USERS)
    ONE THING, since this was my very first pic programming I did NOT use any interrupts for the clock, instead I wrote the program and when I had all finished and working the clock was NOTa real clock ticking every second but instead way to much faster, so my solution was to timed ONE minute of real time against the minutes displayed, and based on that I "IF'ed the program to not enter the decrement seconds seccion until a number of program cicles were reach. and to my surprise and GOOD luck a got a very close aproximation of the time (one second short every five MINUTES of real time, wich for my aplication it's an acceptable error).
    and even the project is finished and working, I was wondering if you could give me an code example of how to use interrups to measure time.
    regards
    and thanks for the help
  1. Crystal oscillator problems on a 16f628a
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 16:33
  2. boot loader for 16f628a ?
    By tdavis80 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2008, 02:07
  3. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 00:44
  4. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 07:42
  5. HSEROUT and 16F628A
    By fredblah in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 00:07
