Indexing Port Pins
Results 1 to 7 of 7
    brighton
    Exclamation
    Hi Bruce / sayzer
    Just being reading your interesting posts about port indexing
    and wanted to know if it was posible to map a variable to different ports
    example say like using a word variable to control the 16bits below
    How to i go about this? Is it possible ?
    RB7 = //MSB
    RB6
    RB5
    RB4
    RB3
    RB2
    RB1
    RB0
    RA0
    RA1
    RA2
    RA3
    RD0
    RD1
    RD2
    RD3 //LSB
    Hope you can help
    Isaac
    Hi Isaac,
    See this thread for some ideas: http://www.picbasic.co.uk/forum/showthread.php?t=4074
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Quote Originally Posted by isaac
    Hi Bruce / sayzer....
    ...using a word variable to control the 16bits below
    How to i go about this? Is it possible ?...
    I do not think you can drive the ports or port pins directly by using alias on them via a the bits of a WORD or BYTE variable.
    For example,
    MYPORT VAR WORD
    PORTA.1 VAR MYPORT.0 is an incorrect arrangement.
    MYPORT.0 VAR PORTA.1 is also incorrect.
    PORTB VAR MYPORT.HighByte incorrect.
    PORTA VAR MYPORT incorrect
    But,
    PORTB = MYPORT
    or
    PORTB = MYPORT.HighByte or PORTB = MYPORT.LowByte can be ok!
    But anyway, in addition to the link that Bruce posted, here I posted an example with the port pins you listed.
    See if it is what you needed.
    'Assuming you have the ports set up.
    Loop    VAR BYTE
    MYPORT  VAR WORD
    MYPORT = 0
    GOSUB DriveMeCrazy  'Pull all pins low.
    Start:
            FOR LOOP = 0 TO 15
                MYPORT.0[LOOP] = 1          'HIGH
                GOSUB DriveMeCrazy
                PAUSE 1000                  'Give it a pause as an example.
                MYPORT.0[LOOP] = 0          'LOW
                GOSUB DriveMeCrazy
            NEXT LOOP
            GOTO START
    DriveMeCrazy:
        PORTB.7 = MYPORT.15
        PORTB.6 = MYPORT.14
        PORTB.5 = MYPORT.13
        PORTB.4 = MYPORT.12
        PORTB.3 = MYPORT.11
        PORTB.2 = MYPORT.10
        PORTB.1 = MYPORT.9
        PORTB.0 = MYPORT.8  'From here to above, "PORTB = MYPORT.HighByte" may also be ok.
        PORTA.0 = MYPORT.7
        PORTA.1 = MYPORT.6
        PORTA.2 = MYPORT.5
        PORTA.3 = MYPORT.4
        PORTD.0 = MYPORT.3
        PORTD.1 = MYPORT.2
        PORTD.2 = MYPORT.1
        PORTD.3 = MYPORT.0
    brighton
    Thanks Bruce /sayzer
    Your examples did help me get it sorted
    you both have being great
    Isaac
    Default Re: Indexing Port Pins
    Update: Cleaned up logic so LEDs always get same current no matter how many are in use.
    When you need to blink a lot of LEDs:
    Here's the results of a current test using 32 LEDs on a 18F44K22 using internal oscillator at 64MHz.
    portLedA    var     PORTA       ' Define Ports
    portLedB    var     PORTB
    portLedC    var     PORTC
    portLedD    var     PORTD
    portLedE    var     PORTE
    byteLoop    VAR     byte        ' Define variables
    byteDelay   VAR     byte
    byteActiveA var     byte        ' Define active pins
    byteActiveB var     byte
    byteActiveC var     byte
    byteActiveD var     byte
    byteActiveE var     byte
    byteRXA     var     byte        ' Define RX data
    byteRXB     var     byte
    byteRXC     var     byte
    byteRXD     var     byte
    byteRXE     var     byte
        portLedA = %00000000        ' Initialize Leds off
        portLedB = %00000000
        portLedC = %00000000
        portLedD = %00000000
        portLedE = %00000000
     byteActiveA = %11111110        ' Determine Active pins     Pin A.0 not used
     byteActiveB = %11111111
     byteActiveC = %00111111                                  ' RX / TX in use
     byteActiveD = %11111111
     byteActiveE = %00000111                                  ' MCLR input only
         byteRXA = %11111110        ' RX data from Master PIC
         byteRXB = %11111111
         byteRXC = %00111111
         byteRXD = %11111111
         byteRXE = %00000111
    byteDelay    = 35               ' Tweak this value to control current and frequency
    ' 1 LED active        668 Hz     2.7 mA LED    14.2 mA circuit
    ' 32 LEDs active      668 Hz     2.7 mA LED    99.0 mA circuit
    ' Using 2N2222 NPN transistor, 4K7 base with 680K pull-down,
    '       LED direct to collector from 5VDC.
    mainloop:
        For byteLoop = 0 to 7                       ' Go through 8 bits
            if byteActiveA.0[byteLoop] = 1 then     ' Check if pin is used
                portLedA.0[byteLoop] = byterxA.0[byteLoop]
                PAUSEUS byteDelay
                portLedA = %00000000                ' Faster than setting bit to 0
            if byteActiveB.0[byteLoop] = 1 then
                portLedB.0[byteLoop] = byterxB.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveC.0[byteLoop] = 1 then
                portLedC.0[byteLoop] = byterxC.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveD.0[byteLoop] = 1 then
                portLedD.0[byteLoop] = byterxD.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveE.0[byteLoop] = 1 then
                portLedE.0[byteLoop] = byterxE.0[byteLoop]
                PAUSEUS byteDelay
        Next byteLoop
        Goto mainloop           ' Go back to loop and blink LEDs forever
    Use byteActiveA-E variables to determine which bits you want toggled.
    Use byteRXA-E variables to receive bits from a Master PIC.
    Use byteDelay variable to tweak current and LED brightness.
    For my testing, MCLR (can only be input), RX/TX (needed) and A0 (unused) were disabled.
    Last edited by Demon; - 6th January 2014 at 05:48. Reason: picture and updated code
  1. Pointers To Port Pins ?
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2009, 20:38
    Last Post: - 14th November 2008, 17:25
  3. Another question RE port line indexing
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 15:23
  5. PIC PORT 'special' pins
    By barkerben in forum General
    Last Post: - 18th January 2005, 21:40
