voltage regulator help - ot
Results 1 to 30 of 30
    Jan 2006
    Here is the full schematic, it includes the LED drivers instead of the mosfets.
    Wink Simple ....
    Hi, Doc
    Looking back to your first post ... make me think using LM350 ( T or K ) or LM 338K's ( 5A )instead of the 317's would be a very good solution ... as it exists some insulating silicone pads ( or Mica sheets ...) and insulating spacers to avoid connecting reg.case to your aluminium casing !!!
    The " best " solution surely is here !!!
    See here i.e. : http://www.selectronic.fr/soussousfa...0&ssfam_ref=30
    or here : http://www.selectronic.fr/soussousfa...0&ssfam_ref=20
    Hangover, Germany
    Cool
    It's not easy for us to understand your problem.
    You are mixing up linear regulators and switching regulators... we don't know what voltage and current you need...
    I think you want to build a luminated heater. You want to burn away a lot of the electric power in your regulators in order to give a little piece of power to your LEDs.
    Think about switching regulators !
    Jan 2006
    The RGB led's need 4.5, 6.7, 7.6 volts respectivly and draw 350mA per color. for a total of 1.05 amps per LED unit.
    I would like to run 7 or 8 of these in parallel, giving me the necessity for 8-9 amps of total current. So 3A per color.
    so to break it down, I need [email protected], [email protected], and [email protected]. Each controlled via hpwm from the pic.
    hope this clears it up
    thanks
    -brian
    Feb 2004
    Germany
    Quote Originally Posted by docwisdom
    ...to break it down, I need [email protected], [email protected], and [email protected]. Each controlled via hpwm from the pic.
    Brian,
    Let's assume the average supply voltage is around 13V
    that gives a total loss of about 60W!
    Earlier you were talking about a "low power solution"
    You should think about a different and more economical approach (switching rather than linear).
    Don't focus on those expensive "fully integrated" switching regulators,
    there are several "low cost" SMPS-controllers available that give good results and high efficiency if you use the right external components.
    Take special care on the inductors, capacitors, mosfets and diodes
    and last but not least the PCB layout.
    With one of my current designs I get close to an efficiency of 90% at competitive costs.
    (SEPIC Converter 120W - Input 8-18V Output 12V@10A)
    regards
    Ralph
    Welcome back Ralph! We miss you!
    Jan 2006
    Ralph,
    Thanks for the post.
    I think you went over my head a little bit with SMPS and SEPIC. Could you throw out a couple specific examples for me, or a website reference?
    thanks
    -=brian
  1. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Project-Read voltage in / different voltage out
    By andydoc in forum mel PIC BASIC
    Last Post: - 8th August 2005, 15:20
  5. Low Voltage Detection
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 18:29
