ERROR Compling 16F819...l but the 16F818 works fine
Results 1 to 8 of 8
Threaded View
  1. #7
    Eveybody can have their own opinion about any IDE but in this case it's not the problem source. In fact, since i use MicroCode Studio i'd never ever have a problem related to the IDE when compiling the code, using the Serial Monitor, Bootloader or else component of.
    NOW, let's see where it may crash...
    ADCIN PORTA.1, X
    Come on.. read carefully the PBP manual, you must write the channel number not the PORT PIN name
    ADCIN 0,x
    true about the Goto Gosub, you must write as
    Pause 50
    If X > 100 Then
            GOSUB  BLINK
    GOTO LOOP
    BUT, i also suspect of a corrupted file in your PBP folder. remove PBP then reinstall it.
    That's definately NOT an IDE problem. Work here with PM and MPASM with both PIC EVEN if i keep the Goto instead of using the GOSUB. I'll keep my own 'flames' about IDE.
  1. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  2. 7805 works fine, LM2940CT5 not!
    By DanPBP in forum Off Topic
    Last Post: - 29th August 2007, 23:01
