2 Decimal Numbers
Results 1 to 8 of 8
    Smile re: 2 Decimal Places
    Excellent! I shall read about the DIG command. Thanks.
    Unhappy re: AD scaling ?
    I made a voltage divider for my project. A 22k and 3.3k resistor with the AD tap across the 3.3k into RA0. The supply varies from 0v to 25.15v. When the math is run, 3.37v across the 3.3k resistor has to equal 25.15v read out on the LCD. This is where I'm hitting the brickwall. How do I scale this to work correctly? I can get a proper readout if I keep the input to the AD at or below 5V. (no voltage divider) I can't go above this because of the voltage limit of the AD. Is this a matter of a equating something to something else using PBP?
    If your maximum voltage is 25.15v, then chose Resistors to give you as close to 5v as possible at your ADC. Right now you're only using 2/3rds of your ADCs scale and limiting your final result accuracy.
    Simple maths from then on (forget the actual voltage across the Resistor)...
    If say a 10-bit ADC reading of 1010 is equal to 25.15v (your maximum) at your potential divider input, then...
    1010*0.0249 will give you 25.149...
    So let's scale everything up for Integer math...
    MyADCWORD is a variable of your ADC reading
    MyVoltageWORD is a variable containing the voltage to be displayed
    TempWORD is just a variable
    TempWORD=MyADCWORD*249
    MyVoltageWORD=DIV32 10
    This above code snippet will give you a result of 25149 which you can then use the DIG command to display upto five significant figures ie 25.149 or if you used DIV32 100 you would have four significant figures ie 25.14.
    To work out the constant (in our above case 249) simply take...
    Constant=Input Voltage/ADC Reading
    ...and just scale everything up accordingly so there are NO DECIMAL PLACES. Ignore the fact we are going to spill out of a WORD variable when we do our multiplication, DIV32 will take care of the final result. Use DIV32 to scale us back so the final Results fits in a WORD variable to the maximum number of significant places you need.
    Finally, remember that DIV32 doesn't like interrupts as they may corrupt the result. So if your are using interrupts, the two lines of code that first multiply and then use DIV32 must be enclosed within an DISABLE/ENABLE pair. If you are not using interrupts, then you needent bother with this.
    Smile re:AD Scaling
    I am a sponge for now, must absorb your good info.
    Thans again Ms. M.
    Question re:2 decimal numbers
    I ran the code Ms M. suggested and after a few setup line changes everything started to come around. I have the voltage divider set for exactly 5 volts to the AD. Here is the bummer: the display says Volts = 0.00 when the power supply is at zero volts, this is OK, but when the voltage is run up the display numbers are showing strobe dimming and are totally incorrect and unstable. The "Volts =" is steady and OK. The numbers vary from above 0.00 to 65.05 volts which is way off since the power suppply only runs up to about 25 volts. Can this be worked out by additional code or by filtering? My digital bench meter is showing a good clean output across the input to the AD which is 0 to 5volts.
    More likely you have the wrong JUSTIFICATION if you are using a WORD variable with your ADC. Check your DATASHEET for your PICs ADC Register settings and the ADCIN defines for the correct number of BITS you have set. If you are using the 16F877 (your first post)... you should have a line something like...
    ADCON1.7=1
    ...somewhere in the initialisation section of your program. To find out in detail what this means, look in the ADC Section of the Datasheet for your PIC. But when using a 8-Bits from your ADC, the Result should be LEFT Justified, whilst when using more than 8-Bits, the ADC Result should be RIGHT Justified (which without seeing any code from you is what I think you should be doing).
    Another reason for your results jumping about is that your sampling time could be too short.
  1. Replies: 4
    Last Post: - 15th April 2009, 01:54
  2. Microcontroller with 2 way paging application problem
  3. show on LCD decimal numbers
    Last Post: - 31st March 2007, 20:36
  4. Returning whole numbers for DS1820?
    Last Post: - 12th February 2007, 12:15
  5. 2 decimal display on LCD
    By pt3rg in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 14:28
