Negative voltage for LCD driving?
Results 1 to 12 of 12
    Jan 2008
    Default Negative voltage for LCD driving?
    I have a display and in the datasheet it says that it need "Negative voltage for LCD driving" on the VO pin?
    What does that mean? can i connect it like itīs discribed in the PBP manual?
    Datasheet
    http://www.vtronic.com.cn/products/images/VT162B-B.pdf
    What happens if you do connect the Contrast pin as per the manual?
    Jan 2008
    I donīt know, i haveīt tryed yet.
    Do you think it will work whitout a negative voltage?
    Well it's not going to harm it.
    You worry about providing a negative voltage if it doesn't work through conventional ways first.
    If you do need a negative voltage, then if you have a PIC that can give you HPWM, we can easily generate one from that with a few components.
    Jan 2006
    Slovenia EU
    3 pin on LCD is normally tied to GND. negative supply is need by extrem contrast or low temperatures.
    You can help with PWM from PIC. see Attachment
    Samo
    Fredrick, You can also use the -9 volts from an RS-232 interface ic if you are using a serial interface to your computer for boot loading.. I do this quite often.
    Jan 2008
    I use a USB interface with a FTDI RS232 chip on the board.
    I will try first and just connect it to GND and se whatīs happends.
    Jan 2008
    Just connect the Vo to GND doesīt work, all the "pixels" on the display are showing but no text.
    I think this display needs negative voltage for LCD driving..
    Jan 2006
    Slovenia EU
    You have problem in software. When show all pixels on display then is contrast ok. Check your data signal
    Quote Originally Posted by Fredrick View Post
    Try connecting as the manual shows with a pot as a voltage divider, then try adjusting until the display is clear.
    Jan 2008
    The display i working now but itīs slow.
    The problem was that i have forgot to connect the "Enable" signal, i checked the connections severel times before i notice that. I have must been tired
    Do not tell anyone, but I made a similar mistake awhile back.
  1. Driving a Voltage Regulator with PWM
    Last Post: - 27th June 2007, 13:14
  2. PIC driving Adjustable Voltage Regulator
    Last Post: - 6th June 2007, 20:05
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 12:12
  5. Help Read negative voltage
    By gzorzi in forum mel PIC BASIC Pro
    Last Post: - 25th October 2004, 07:42
