Need help building a simple IR learning remote with a PIC
Results 1 to 15 of 15
    I was up working on this all night, see what you think.
    Assumptions based on ProntoEdit data:
    The carrier is 40K
    Header code: 4.12ms ON , 3.75ms OFF
    Trailer code1: 11.25ms ON, 3.75ms OFF
    Trailer code2: 11.25ms ON, 90ms OFF
    Data 0 = 1.15ms ON, 6.35ms OFF
    Data 1 = 3.55ms ON, 3.75ms OFF
    Data Stream:
    Header Code - IR data (eg off) 0010 - 0 spacer - Trailer Code1 -
    Header Code - Inverse of IR data (eg 1100) - 1 spacer - Trailer Code2
    I see that the PICs cant output a frequency greater then 32767Hz so I plan on ANDing a 555 output with the data stream. Haven't had a chance to test any of this yet. I am also not sure that my timing is accurate (ms ON, MS off).
    This is the OFF string (from ProntoEdit)
    0000 006b 000c 0000 00a5 0096 002e 00fe 002e 00fe 008e 0096 008e 0096 008e 0096 008e 0096 008e 0096 002e 00fe 002e 00fe 002e 00fe 01c2 0e10
    This is the ON string:
    0000 006b 000c 0000 00a5 0096 002e 00fe 002e 00fe 008e 0096 002e 00fe 008e 0096 008e 0096 008e 0096 002e 00fe 008e 0096 002e 00fe 01c2 0e10
    Dec 2005
    That's a shame. I can analyze any CCF code in a minute or two, including a graph of the code. A graph of the ON code is attached.
    What PIC do you plan to use? It's easy to get higher frequencies using hardware PWM. I do it with a PIC12F683 but you'll probably want more pins. There's an example program on the Reynolds Electronics website. Here's some test code that generates ~120kHz.
    DEFINE OSC 8
    @ DEVICE PIC12F683, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC12F683, MCLR_OFF
    TRISIO.2 = 0				'GPIO.2=Output
    PR2 = 17			        'PWM Period   117.7kHz
    CCPR1L = 8				'PWM Duty-Cycle
    'CCP1CON = %00001100  			'PWM Mode
    T2CON = %00000100    			'Timer2=ON, 1:1 prescale
    OSCCON = %01110001                      'INT HF OSC 8MHz
    WHILE OSCCON.3>0: WEND                  'OSC startup timeout
    WHILE OSCCON.2=0: WEND                  'INT HF OSC stable
    'CCP1CON = 0 'PWM module off
    WHILE OSCCON.2>0
      CCP1CON = %00001100 'PWM ON
      PauseUS 1000        'generate 1ms burst
      CCP1CON = 0         'PWM OFF
      Low GPIO.2
      Pause 10            'pause 10ms
    WEND
    I get somewhat different values.
    • Carrier=38740
      Lead-in=4.259ms ON, 3.872ms OFF
      1-bit=1.187ms ON, 6.557ms OFF
      0-bit=3.665ms ON, 3.872ms OFF
      Lead-out=11.616ms ON, 92.928ms OFF
    If all codes use the same lead-in & lead-out, the binary codes are 1100 0001 11 and 1101 0001 01 for OFF & ON respectively.
    Thanks to everyone for all their help so far.I was stupid enough to stay up all last night working on this project, and now I am so fried I can barley think!
    I threw together a quick circuit & program, but it does not appear to be sending usable IR. At this point I could be missing something really basic and think I need to change gears for a few hours.
    dhouston's sample code appears to be for an oscillator. How would I reduce this down to the Hz needed for my carrier? Is this program specific to the PIC12F683, or can I use it on a 12F629, 12F675 or 16F88 (chips I have available now)? Would this PIC just be used to generate the carrier, or could it also generate the complete IR stream including carrier & data pulses?
    Thanks - know I will be back in the morning, against my better judgment
    Dec 2005
    Quote Originally Posted by JackPollack
    It can generate everything you need, turning the carrier on and off as my demo code does within the loop. It requires a PIC that has hardware PWM. I think the 16F88 is the only one in your inventory with that capability. Get some sleep. This is too simple a project to lose sleep over.
    Now I don't want to get involved in this thread... but I thought a 'Learning Remote' (see title of thread) is one where you point an existing Remote to your Learning Remote, it captures the Data Stream, and assigns it to one of your available Buttons. The Learning Remote doesn't need to know if it's a Sony, JVC or a Zenith, all it needs to do is faithfully capture the incomming data and replicate it on demand. If you go and pre-program your Data into your PIC at burn time, it's then not a 'Learning Remote' is it?
    Feb 2003
    Quote Originally Posted by Melanie
    Too late
    Good point. I guess I didnt read the original post well enough!!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Dec 2005
    That depends on the PIC and its oscillator rate. PR2 sets the period of the carrier and CCPR1L the duty cycle. Read Bruce's article for the details...Since only one pin is needed to output the bursts of IR carrier, you could do this with the 12F683 - the 5 free pins can support 32 buttons. I assume you want this small and battery powered.
    I've done a few learning remotes. I can't give you all of it, but I can share a few little odds & ends you might find useful.
    This simple routine allows you to output your carrier bursts on any pin that can be used as an output, and it's easy enough to modify for most any carrier frequency.
    Note this assumes a 4MHz osc. Internal or external work equally well.
    @ #define IRTX PORTC ; Define port to use for IR out
    @ #define PIN 2          ; Define port pin to use for IR out
    ' Note: Be sure to make the above pin an output
    TRISC.2 = 0
    PORTC.2 = 0 ' LED off on boot
    Cycles VAR BYTE ' Make sure this is always located in bank0
      GOTO Main     ' Jump over routine to main program entry point
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse      ; + 2uS = 12uS
       return           ; Return to caller
    Using this is very easy. Load the number of carrier cycles into Cycles, then CALL Pulse.
    If you need a carrier burst longer than 255, simply call Pulse again immediately after the 1st call. IR detectors are relatively slow in responding, so it's unlikely you'll see a break in the burst on the receiving end. I never have.
    Can't share the larger routine with you, but this shows one simple approach to getting the IR output on any pin.
    Making a learning remote isn't really all that hard, but it can be memory hungry depending on the width of carrier bursts, data packets, etc, the IR remote you're learning outputs.
    Learning a single remote is much easier than a boat load of different brands.
    TIP: Use PULSIN to read & store each logic 0 carrier burst width into an array. The first low pulse is normally a synch pulse, then data. Some remotes will include a long carrier burst period between each packet. That will vary from one mfg to another.
    Run through a second PULSIN routine waiting for the logic 0 synch pulse, then start recording/storing the logic 1 periods.
    These will be the periods where you PAUSEUS between loading Cycles & calling Pulse when recreating the outgoing data.
    TIP #2: My first learning remote I made the user press a button until I had sorted all out logic 0 (carrier burst periods), then lit an LED telling the user to release the button. The same button was pressed once again, and it learned the logic 1 periods between carrier bursts by synching up with the initial logic 0 synch burst. Viola! Codes all learned & stored.
    You end up with the whole data pattern, and it's pretty simple from there to re-create the same IR signal.
    TIP #3: I eventually used a PIC where I could switch oscillator speeds on the fly, read in pulses at higher speeds for better resolution, then switched back down to the lower osc speed to send, and finally to the lowest speed and entered sleep for ultra low power use until a keypress. Worked really nifty.
    Hope that helps. If you want a few more IR goodies contact me off-list. I can share a couple more routines with you if it's 100% for personal use.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Italy
    See these links.
    Best regards,
    Luciano
    IR Remote Control info:
    http://www.xs4all.nl/~sbp/knowledge/ir/ir.htm
    Hacking Remote Control Signals:
    http://www.i-hacked.com/content/view/121/94/
    (It is difficult to see the pictures on this page. Copy
    the pictures and paste them in the Windows Paint).
    Where to download the SW DigiTrace:
    http://www.xs4all.nl/~jwasys/old/diy2.html
    With a driver DigiTrace will run also on W2k and XP.
    Be careful using the parallel port of your PC !!!!!!
    If possible, install a second parallel port in a PCI slot.
    See also this one:
    http://www.hifi-remote.com/forums/viewtopic.php?t=3569
    Thanks again to all that helped. After a little sleep I found that the current limiting resistor on my IR LED was 10K. Anyway, lowered it and everything is working.
  1. remote code learning
    Last Post: - 21st February 2021, 15:38
  2. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  3. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 13:26
  4. Serial Pic to Pic using HSER
  5. multiplexing IR array into PIC 16C7x
    By droptail in forum General
    Last Post: - 17th November 2004, 18:30
