LCD question
Results 1 to 7 of 7
Thread: LCD question
    Sep 2005
    Default LCD question
    I have an lcd which is not serial driven can i still use it with pic basic or is there a circuit that will convert into a serial driven display?
    Also is there a good source for lcd displays on the net
    Pinckney, Michigan
    You need to determine if the LCD you have has an on-board controller, or just row and column drivers. If it has an on-board controller, you can most likely drive it directly with a PIC. If you're REALLY lucky it will have an on-board SERIAL port, which makes it real easy.
    Do a Google search on "Serial LCD" to educate yourself as to the differences of the various on-board controllers and serial port versions.
    Sep 2005
    hi my lcd does not have a serial pin
    can i still drive it useing pic basic or is there a circuit diagram i can use to make it possible to use
    Have a dedicated PIC wich will drive your LCD by using LCDOUT command. The default schematic is shown in the LCDOUT section of the PBP manual.
    at the end the huge thing should look something like
    Start:
        SERIN SerialInput,SerialMode,SerialData
        LCDOUT SerialData
        GOTO start
    Hangover, Germany
    Angry
    Look inside the documentation of PicBasic Pro and read around the LCDOUT-command. There is a drawing to connect "normal" LCDs.
    Seriel LCDs are "anormal".
    Maybe there will be a typenumber on your display. This will help us to find the documentation for you.
    Sep 2005
    Thanks thats great still new to this.
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
