Piezo input
Results 1 to 5 of 5
Thread: Piezo input
    a few seconds on google may give you some help too
    http://devices.sapp.org/circuit/piezo/
    Probably i would forget the LowPass and impedance buffer stages. Never use it before.
    Another idea, that 'could work', is to use a PIC with an internal Comparator. You just need to read the comparator output. I think! Using that, you may implement a software threshold as in some Musical Drums Pad (wich may use those sensor or not...)
    Saying that, the sensor impedance may give you some problem.... or not without a 'preamp' or 'buffer' Some bench test will says you all.
    Good luck!
    PS about the diode... if you use a single rail OP-AMP you'll don't need it. If you use the internal PIC comparator, use a serie resistor and the internal PIC diode may do the job. 1N5817 are still cheap, and almost diode could do the job. It's not as this critical IMHO.
    I found an interesting application link so far
    http://www.media.mit.edu/physics/ped...l-photos2.html
    Enjoy!
    Apr 2006
    Very interesting... Thanks again, I appreciate it.
    Tony
    Sep 2005
    Default Piezo for a gyro
    Could you use a piezo sensor for a gyro?
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 23:21
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
