HEX numbers
Results 1 to 4 of 4
Thread: HEX numbers
    Sep 2005
    Campbell, CA
    Default HEX numbers
    Is there an easy way to separate the "digits" of a hex number?
    For example 63251 = F713, but I need to separate out each digit
    as ASCII into an array element.
    e.g.
    NumArray[0] = "F"
    NumArray[1] = "7"
    NumArray[2] = "2"
    I know there must be an elegant way, but I can't think of it.
    Charles Linquist
    Feb 2005
    Kolkata-India
    Default Try this link.
    Sougata
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I don't know if it is elegant but ...
    X var WORD
    Y var BYTE
    NumArray var BYTE[4]
    X = 63251
    Y = X.lowbyte & $0F ' isolate the lower nibble
    gosub ConvertAscii
    NumArray[3]=Y ' ="3"
    Y = X.lowbyte >> 4 ' move high nibble to low nibble
    gosub ConvertAscii
    NumArray[2]=Y '="1"
    Y = X.highbyte & $0F ' isolate the lower nibble
    gosub ConvertAscii
    NumArray[1]=Y '="7"
    Y = X.highbyte >> 4 ' move high nibble to low nibble
    gosub ConvertAscii
    NumArray[0]=Y '="F"
    ConvertAscii:
    If Y < 10 then
    Y = Y + 48
    Else
    Y = Y + 55
    Endif
    Good Luck,
    Paul Borgmeier
    USA
    Sep 2005
    Campbell, CA
    After I posted I realized that I had the answer all along. I wrote an Intel Hex routine awhile back. It dealt with bytes only. All I had to do was to use the routine twice - very similar to your approach.
    Thanks for responding!
    Charles Linquist
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 02:10
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. Replies: 4
    Last Post: - 15th April 2009, 02:54
  5. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 07:40
