4x3 keypad
Results 1 to 10 of 10
Thread: 4x3 keypad
    Jan 2006
    Default 4x3 keypad
    First off I would like to thank bruce for this code from his site.
    '* Name : serkey16.bas *
    '* Author : Reynolds Electronics *
    '* Date : 07/12/2001 *
    '* Version : 1.0 *
    '* Notes : PicBasic Pro program for 16-key serial keypad *
    INCLUDE "modedefs.bas"
    col VAR BYTE ' Keypad column
    row VAR BYTE ' Keypad row
    key VAR BYTE ' Key value
    baud VAR PortA.0 ' Baud select pin
    serpin VAR PortA.1 ' Serial output pin
    CMCON = 7 ' PortA = digital I/O
    VRCON = 0 ' Voltage reference disabled
    TRISA = %00000001' PortA.0 = baud select pin
    OPTION_REG.7 = 0 ' Enable PORTB pull-ups
    loop:
    GOSUB getkey 'Get key from keypad
    send:
    IF baud = 1 THEN fast'If baud = 1 then N9600,else N2400
    SEROUT serpin,N2400,[key]'Send key value out PortA.1
    GOTO loop
    fast:
    SEROUT serpin,N9600,[key]
    GOTO loop 'Do it forever
    getkey:
    PAUSE 50 'Debounce key-input
    getkeyu:' Wait for all keys up
    PORTB = 0 ' All output-pins low
    TRISB = $f0 ' Bottom 4-pins out, top 4-pins in
    IF ((PORTB >> 4) != $f) THEN getkeyu'If keys down, loop
    PAUSE 50 ' Debounce key-input
    getkeyp:' Wait for keypress
    FOR row = 0 TO 3 ' 4 rows in keypad
    TRISB = (DCD row) ^ $ff ' Set one row pin to output
    col = PORTB >> 4 ' Read columns
    IF col != $f THEN gotkey' If any keydown, exit
    NEXT row
    GOTO getkeyp ' No keys down, go look again
    gotkey: ' Change row and column to key number 1 - 16
    key = (row * 4) + (NCD (col ^ $f))
    'NOTE: for 12-key keypad, change to key = (row * 3)
    RETURN ' Subroutine over
    I would like to use this in only a 12 key configuration. This leaves me with 7 data pins required.
    In this code Bruce makes use of all 8 PortB pins. Unfortunately these arent available to me because they are currently being used for HPWM and a parallel LCD.
    My question is, with these ports available (no 8 in sequence) how can I modify this code to work.
    RA0, RA1, RA2, RA3, RA4, RA5, RB7, RC0, RC4, RC5, RC6, RC7
    I am using a 16F767.
    Thanks in advance,
    -brian
    Jan 2006
    Istanbul
    Cool Multiple Buttons Using One Pin
    May I recommend the attached schematic as a solution to your limited pins?
    With the attached schematic, pot command can be used to read different values of each button hit. Even the combination of button hits can provide different readings.
    The key points are as follows.
    1. All resistors must be +/-1% or better tolerance.
    2. This application may not be suitable in the environments where ambient temperature changes sharply.
    3. “Select Case“command needs to be used to divert the resistor readings.
    Example:
    Pot porta.0, 255,BtnRead
    Select Case BtnRead
    Case is >20 and is <25 ‘Actual BtnRead=22, The safe reading range is wider then the resistor tolerance.
    Goto Menu1
    Case is >26 and is <31 'Actual BtnRead=28
    Goto Menu2
    End select
    4. Resistor values need to be determined experimentally. If the values are too close then the range of one button may intersect with the range of another button.
    a custom copy/paste solution for any kinda matrix keypad... well max 8X8
    http://www.picbasic.co.uk/forum/showthread.php?t=3250
    Yeah i know it's code hungry... one day i'll work on it again... one day!
    Jan 2006
    mr-e,
    thanks for the code, it looks very simple and easy to use, however, it must be a little too complicated for me because I am getting nowhere. Maybe you can find something stupid and obvious, but I cant find it.
    here is your code modified to my use
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 4/13/2006 *
    '* Version : 1.0 *
    '* Notes : *
    TRISB = %10000000
    ADCON1 = %11111111 'all ports digital
    INCLUDE "KeyPad.bas"
    ' Hardware connection
    DEFINE KEYPAD_ROW 4 ' 8 row
    define KEYPAD_ROW_PORT PORTA ' on PORTA
    DEFINE KEYPAD_ROW_BIT 0 ' <3:0>
    DEFINE KEYPAD_COL 3 ' 3 col
    DEFINE KEYPAD_COL_PORT PORTC ' on PORTC
    DEFINE KEYPAD_COL_BIT 4 ' <7:4>
    DEFINE KEYPAD_DEBOUNCEMS 200 ' debounce delay = 200 mSec
    define KEYPAD_AUTOREPEAT 0 ' use auto-repeat
    ' Serial Communication definition
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0)
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us
    DEFINE LCD_DATAUS 50 ' Set data delay time in us
    ' Variables definition
    myvar var byte
    ' ---------------------------------[Program Start]----------------------------------------------
    lcdout $fe, 1, "Hello"
    start:
    @ READKEYPAD _myvar
    lcdout $fe, 1, "Key=", DEC myvar
    goto start
    I threw the "Hello" in there just to test that it programmed correctly and the LCD is functioning.
    When I press any button, it still just says hello. So something in the button config aint workin.
    I am using Microcode studio 2.3, PBP2.46, and MPASM.
    I have my rows hooked up with 4.7k pullup resistors as you stated and they are pinned to RC4-6. I also have the columns hooked up with 4.7k series resistors (too high a value?) to RA0-3.
    thanks again for posting your code.
    In fact you MUST use some low value for column, let's say 100-300 ohms. 4.7K is way too high. The PIC don't detect the LOW level signal. In best case the LOW level will be 2.5 volts... too high for a LOW level signal Refer tosection 18.4 of your datasheet for that.
    You can even remove the column resistor and plug it directly... it will work but it's not really recommended.
    Another thing, you must disable analog comparator too on PORTA
    ADCON1=$0F    ' Disable AD converters
    CMCON =7      ' Disable analog comparator
    About now?
    PS: you can remove the DEFINE KEYPAD_AUTOREPEAT line. If you don't write it, the program will set it to off for you. This refer to that section of the include file
                          @ ifndef KEYPAD_AUTOREPEAT           '       If AutoRepeat is not DEFINE
                                   repeat
                                       Gosub readcol           '           Wait until
                                       until KeyTemp=keymask   '               Key is released
                                   @ endif
    Jan 2006
    Thanks very much steve.
    I have it running and the keys are being read. I tried using low value resistors on the columns but it didnt work, but low value resistors on the rows and it started reading.
    One problem though, The first two rows are working perfect, but the second two rows will change values every time I press the button.
    these columns.
    The two affected rows are connected to the VREF pins on PORTA, is there a disable config for VREF? or is it default disabled?
    one more question also while your peeking at this thread. is there a way to make the auto repeat work only on 2 buttons? Two buttons on my kepad are +- adjustments and all the others are command buttons. It would be great to make the +- buttons autorepeat.
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. keypad 4x3
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 15th July 2009, 07:34
  3. 4x3 keypad and an LCD.. need help.
    By taisen83 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2009, 10:34
  4. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  5. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
