Using ADCIN or POT/RCTIME?
Results 1 to 12 of 12
    If you have an analog signal from some external device, say, a temperature
    sensor or something else, that outputs an analog voltage, then you can
    connect this analog source directly to the PIC A/D input.
    If you're using a potentiometer to simulate the external analog signal, then of
    course you'll want one end to Vcc, the other to ground, and the wiper to the
    PIC A/D input.
    Without one leg of the potentiometer to Vcc you wouldn't have anything but
    ground on the PIC A/D input.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    AND be sure you POT or ELSE analog source meet the maximum A/D input impedance.
    If you plan to use a PhotoResistor, you will need to pass the PhotoCell trhough an OPAmp or else method.
    look the PIC datasheet (once again) to know the maximum PIC A/D impedance
    Apr 2006
    Default Rctime
    Ok, thanks for the info.
    So RCTIME is just measuring the time for a cap to discharge, but the voltage source is coming from the pic pin itself, when it goes from low to high. In this case you would just hook the pot up like what's described for using the POT command? (None of the pots pins to Vcc)
    Thanks again,
    Tony
    RCTIME and POT command are just 'usefull' when your PIC don't have any AD converter. While it's just a pain and real waste of time to do some intelligent calibration, forget them. Choose a PIC with internal AD or use an external one. If you use an external one you'll discover really fast that it just don't worth the investement while a PIC with internal AD are not really much expensive than others without.
    Your POT is connect between VCC and GND, the wiper can go directly or through a low value resistor to your PIC AD input.
    If your software don't provide any noise cancelation, i suggest to add a ~0.1uF between PIC input and GND to filter the signal a little bit.
    If you use the above method, your POT impedance must meet the maximum PIC AD impedance too. Look into your PIC datasheet under the AD section, you'll fiond it there.
    BUT if you don't have any POT that meet it, you can even place a buffer between your POT and the PIC. almost any decent op-amp will do the job.
    ADCIN is easy to use and work really fine even if you can do it simply by writing/reading directly to the internal registers. That will also provide tighter code.
    Apr 2006
    I see. So the POT and RCTIME are useful if your pic doesn't have an a/d convertor.
    Thanks for the info on the circuit, using a resistor before the pin and the cap for filtering. I appreciate it.
    I'm looking in one of the books for A/D conversion. They show a 50K pot, the wiper going directly into the pic pin, but there is a 15K "pull-up" resistor connected from the +5V to the pot. Is this recommended?
    Could be a soultion but i feel the POT will lost his linearity response. well i think
    Let's do some math
    1/5 pot maximum position:
    in theory, we should have 1/5 Vcc on the wiper = 1 Volt
    voltage divider resistor are 10 and 40K
    Voltage divider ratio is 10/50K
    Using the 15K pull up....
    (10//15)/40K
    voltage divider ration is 6/46
    Voltage on the wiper = 6/46 * 5 = 0.65 Volts
    1/2 pot maximum position:
    in theory, we should have 1/2 Vcc on the wiper = 2.5 Volt
    voltage divider resistor are 25 AND 25k
    Voltage divider ratio is 25/50K
    (25//15)/25K
    voltage divider ration is 9.3/34.3
    Voltage on the wiper = 9.3/34.3 * 5 = 1.36 volt
    and so on. Unless your application can deal with that kind of un-linear curve, yes you can use it. I'm not a fan of it
    Apr 2006
    Thanks for that. I see what you're saying. Thanks again
    Tony
  1. ADCIN and PIC18F4331 Arghhhhh !
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 6th December 2010, 21:27
  2. How to make adcin stable?
    Last Post: - 20th January 2009, 08:41
  3. ADCIN problems with PIC16F73
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 12:38
  4. Adcin or Pot
    Last Post: - 11th January 2007, 17:46
  5. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 08:46
